91 integra horn problems
Old Jan 14, 2014 | 04:00 PM
keslerbuilt's Avatar
Default 91 integra horn problems
okay so my horn randomly quite working. i checked the fuese twice i checked to see if it was a ground or hot wire, i took the horns amd put them on my other da amd they worked amd took the steering wheel and put ln the other da and it worked. so its not the wheel,horn, or fuses. so what else could it be? ive made sure all the wires are connected
Old Jan 15, 2014 | 12:39 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: 91 integra horn problems
An open in between the wheel contact switch and the horn plug.
Push the horn and see if you get and power at the connector of the horn.
If not, I'd check continuity between the wheel connector and the horn wires.
Idk what pin it it on the connector on the wheel.
If you have continuity, the connector that plugs into the wheel steering column and the wire harness under the dash is bad.
Someone correct me if I'm wrong
mastashea20
Audio / Security / Video
Aug 8, 2010 06:01 PM
dc2_97teg
Oct 18, 2006 08:43 PM
DC5Danny
14
Jul 18, 2006 08:16 PM
ww91crx
Nov 16, 2004 03:34 AM
