whats the best intake manifold for a turbo b18a
Old Jan 1, 2007 | 04:24 PM
mikeypopshondas's Avatar
Default whats the best intake manifold for a turbo b18a
i'm tryin to find some hp gains on different intake manifolds before i just go out and buy one and hope for the best.
Old Jan 1, 2007 | 04:32 PM
NJIN BUILDR's Avatar
Default Re: whats the best intake manifold for a turbo b18a (mikeypopshondas)
I'm using a stock non-egr one.I think the stock ones will flow as good as a stock head flows.Cranking the boost up a pound or two will probably make more power than a new intake manifold.
Old Jan 1, 2007 | 08:55 PM
blinx9900's Avatar
Default Re: whats the best intake manifold for a turbo b18a (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Cranking the boost up a pound or two will probably make more power than a new intake manifold.</TD></TR></TABLE>
but if you could make more power without adding stress to your motor thats much better, i recomend AEBS becuase there cheap and good you can get them here http://racespecialists.com/Mer...de=IM and other places too. $160... why not?
Old Jan 1, 2007 | 09:02 PM
Speed Infliction's Avatar
Default Re: whats the best intake manifold for a turbo b18a (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
but if you could make more power without adding stress to your motor thats much better, i recomend AEBS becuase there cheap and good you can get them here http://racespecialists.com/Mer...de=IM and other places too. $160... why not?</TD></TR></TABLE>
maybe...but hp is stress on your motor, so i would also look at cranking up the boost.
Old Jan 1, 2007 | 09:07 PM
blinx9900's Avatar
Default Re: whats the best intake manifold for a turbo b18a (Speed Infliction)
yeah but a bigger better designed mani is just getting power from efficiency. i'd rather get the mani, no pint in going back to a dyno for a 1-2 psi raise, but then again you gotta go there anyway if you want to optimes the addition of the mani. either way you gain power huh?
Villenurve
Nov 4, 2007 01:37 PM
namm
Jun 27, 2007 05:37 PM
AEMintegra22
Jun 10, 2006 08:42 AM
Home Wrecker
Feb 23, 2006 10:13 AM
allmotorchick
39
Jan 4, 2004 05:09 PM
