can u remove the tranny alighnment plug to reinstall tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic01 »</TD></TR><TR><TD CLASS="quote">i changed clutch and cant get the tranny to align with the plug on the engine,can this be removed???</TD></TR></TABLE>
Means you misaligned the clutch. Did you use a clutch alignment tool? Just loosen the pressure plate and make sure it's centered real well. Retighten the pressure plate and the tranny should line up fine.
Screw that...you dont need dowel pins..they just make it even more of a pain the in the *** to put the tranny on especially under the car...Oh and i needed my dowel pins for my head
since the machine shop didnt give mine back.. And what "plug" are you talking about?
OBDII Integra
Sep 11, 2009 08:56 PM
we believe the plug hes referring to is the dowel pin.
