Check Engine Light Question???
How do I reset the light? I fixed my O2 Sesor probelm and now need to turn off the light...Isn't there away of doing?
Thanks in Advanced!
Thanks in Advanced!
1. Remove negative battery cable
2. Wait 5 minutes
3. Replace Negative battery cable
Or, if you want it erased, then drive to Checker/Schucks/Kragen/Autozone/PepBoys/O'Reily's/ Whatever and have then run the code, and then clear it.
2. Wait 5 minutes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">1. Remove negative battery cable
2. Wait 5 minutes
Or, if you want it erased, then drive to Checker/Schucks/Kragen/Autozone/PepBoys/O'Reily's/ Whatever and have then run the code, and then clear it.</TD></TR></TABLE>
I see too much time in that as you actually have to get a rachet out.
Pull the "backup fuse" in your fuse box, it's the ECU fuse, then wait 5 minutes (I think haynes says you only need to wait 20 seconds, but whatever) and plug the **** back in.
This is the fuse box in your engine bay...not the under dash one.
2. Wait 5 minutes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Being as my sticker is missing, and I know exactly where my ratchet is .... </TD></TR></TABLE>
Ah, I suppose that's a good argument.
Though it's generally pretty rare that the sticker is gone on the fuse box in the engine bay - the under-dash, sure, but usually not the one in the engine due to pple generally keeping their engine dry and such, they don't "accidently kick it" and such.
- I hear ya tho, I just find the fuse easier to pull (b/c it's right there) then to unbolt the terminal, pull it off, wait, put it back on, then tighten it :-\.
- I hear ya tho, I just find the fuse easier to pull (b/c it's right there) then to unbolt the terminal, pull it off, wait, put it back on, then tighten it :-\.Thread
