speed sensor
Old Jan 1, 2007 | 08:50 AM
ugly rex's Avatar
Default speed sensor
where is the speed sensor located for D16A9...?some say located at tranny n i try to check ..only speedo cable....izzit connection with the speedo meter...?need help....ASAP..thkx
Old Jan 1, 2007 | 09:42 AM
Super Chicken's Avatar
Default Re: speed sensor (ugly rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ugly rex &raquo;</TD></TR><TR><TD CLASS="quote">where is the speed sensor located for D16A9...?some say located at tranny n i try to check ..only speedo cable....izzit connection with the speedo meter...?need help....ASAP..thkx </TD></TR></TABLE>
If you're asking what I think you are it's in the speedometer itself. Intergrated with the instrument cluster.
Old Jan 1, 2007 | 09:56 AM
dr_latino999's Avatar
Default Re: speed sensor (Super Chicken)
CABLE DRIVEN CLUSTER ONLY
Well the Vehicle Speed Sensor is in the transmission, the source though of the electronic signal that the ECU reads comes off the cluster.
Old Jan 1, 2007 | 10:08 AM
Targa250R's Avatar
be professional
The actual VSS is located on the back of the gauge cluster, where the speedometer cable attaches. The speedometer gear assembly is located on/in the transmission, at the other end of the cable.
Old Jan 1, 2007 | 08:09 PM
ugly rex's Avatar
Default Re: speed sensor (Targa250R)
my problem is my speedo meter n pivot speed meter isnt working at all..the ecu give out code 17....(blink 17 times)....have change speedo meter n still not working......have check wif my workshop,he say speedo cable no problem..only speedo meter problem...change it n still the same....check all the wire all connected....
Old Jan 1, 2007 | 08:12 PM
Well the ECU wouldn't blink 17 times to show a code 17, it'd blink a total of 8 times.
One Long
Seven Short
17
Old Jan 1, 2007 | 08:29 PM
SHUTTLE's Avatar
mine was blinking 17 times till i changed the speedo cable code 17 VSS just change your speedo cable
Old Jan 1, 2007 | 08:46 PM
Default Re: (SHUTTLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHUTTLE &raquo;</TD></TR><TR><TD CLASS="quote">mine was blinking 17 times till i changed the speedo cable code 17 VSS just change your speedo cable</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Well the ECU wouldn't blink 17 times to show a code 17, it'd blink a total of 8 times.
One Long
Seven Short
17</TD></TR></TABLE>
Old Jan 1, 2007 | 10:41 PM
gospeedgo1's Avatar
Default Re: (dr_latino999)
according to the downloadable manual (crx workshop, page 125), it blinks for the total amount. 17 is the vehicle speed sensor. well for obd 0 ecu's. The manual only lists 17 codes. it appears it does it differently for obd1, etc, like long and short flashes. my CEL also comes on for code 17. check your cable to make sure its not broken, and that its held in the tranny hole with the little C clip thing, also you will need to take off your speedo cluster and try reattaching the speedo cable where it connects to the cluster, if i pulled on the cable with pliers where it connects to the speedo cluster and then plug it in, it worked and wouldnt give me a CEL for a month or two.
Old Jan 1, 2007 | 11:19 PM
ugly rex's Avatar
Default Re: (gospeedgo1)
will replace my speedo cable....thkx for the info....cheerz........
94whitegsi
Aug 16, 2006 12:11 PM
k7q
18
Mar 25, 2006 04:44 PM
mkinpwrat12g's
14
Aug 22, 2005 09:10 AM
APEX CRX
Jul 27, 2005 01:38 PM
slow4dr
Dec 27, 2004 07:19 AM
