cooling system
Old Jan 1, 2007 | 04:52 AM
kknight's Avatar
Default cooling system
I have a 93 honda civic and neither of the cooling fans will run; however, when i wire either fan direct to the battery both operate. I have replaced the fan relay in the fuse box and the temperature switch on the thermostat housing. What am i missing?
Old Jan 1, 2007 | 05:57 AM
john666's Avatar
Default Re: cooling system (kknight)
im guessing your talking bout the radiator fan.. check the fuse.. could be the relay under the hood... the other fan i believe your talking about is for the ac.. so that one shouldnt be on inless u turn your ac on.
Old Jan 1, 2007 | 05:59 AM
bart2546's Avatar
Default Re: cooling system (john666)
When you say switch on the t-stat housing, are you referring to the coolant temp. sensor? When mine quit working it was because the wires to that sensor were disconnected.
Old Jan 1, 2007 | 01:39 PM
kknight's Avatar
Default Re: cooling system (bart2546)
hey John, thanks for the reply, where is the fuse located?
Old Jan 1, 2007 | 01:43 PM
kknight's Avatar
Bart,
the sensor switch is connected.
at least as far as I can tell, the connector 'clicks' when it seats.
boots420
Dec 23, 2007 03:22 AM
-Championship-
Nov 14, 2006 10:38 AM
harveyy
17
Mar 1, 2006 04:32 AM
screen_name
23
Jul 22, 2005 06:48 PM
turbo*s2k
Oct 28, 2003 08:05 AM
