low rpm misfire, lack of power???? help please
Old Jan 1, 2007 | 01:16 AM
c.0.b.'s Avatar
Default low rpm misfire, lack of power???? help please
So my car starts misfiring at idle, and i barely notice it, just small varations in the car's exhaust note, but within a week of me noticing the random drops in rpm while idling, the car starts to sputter in low rpms in every gear, and stalled once in third and while idling at a light. There is a noticable loss in acceleration/power, and the brakes feel sloppy as well, with more pedal travel required to come to a stop. In addition, the ac blows harder and the headlights shine brighter when at 3k rpms then they do at idle; when you let off the gas, you can see the lights dim.
I've experienced the idle/misfire problem before, it was due to a dirty fuel filter, which i replaced, and the car ran fine. So i've already replaced the fuel filter this time, with no luck. Could it possibly be the fuel pump? The motor has 160k on it, with the distributer replaced at 110k...Any help would be welcome, this is driving me nuts.
And yes, i've searched.
EDIT: There are no misfires at idle when the engine is cold; there is still the lack of power, but the engine does not misfire. In addition, the engine only seems to misfire under 3k rpms, no matter what gear you are in.
Old Jan 1, 2007 | 06:55 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: low rpm misfire, lack of power???? help please (c.0.b.)
Perform a compression check. Your valves could be out of adjustment. Is your Integra ODBII (96-01)? Are there any CELs?
Old Jan 1, 2007 | 11:28 AM
c.0.b.'s Avatar
Default Re: low rpm misfire, lack of power???? help please (Dogginator)
it's a 95 integra gsr, OBDI, and the check engine light is not on.
Old Jan 1, 2007 | 11:38 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c.0.b. &raquo;</TD></TR><TR><TD CLASS="quote">it's a 95 integra gsr, OBDI, and the check engine light is not on.</TD></TR></TABLE>
OBDII would have helped you with misfire detection. Try the compression check as it is cheap, easy, and informative. Also, look at the spark plugs when you pull them.
Old Jan 1, 2007 | 12:26 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Convert to OBDII and pull the codes so we can better diagnose the problem.
Seriously, get a diagram of all your grounds, clean them all up, and make sure they're all nice and secure.
Old May 12, 2010 | 01:35 PM
4.8t's Avatar
could a bad o2 sensor lean it out when warmed up and cause this? my car is doing the same thing right now.
Old May 13, 2010 | 09:03 AM
fsg231's Avatar
if you can power out of the miss-fire its usually secondary ignition ...( plugs and wires )
Old Apr 29, 2011 | 11:56 AM
SilverEF88's Avatar
Ok, old thread I know but If anyone is having this issue...I was having the same problem and it was the O2 sensor.
Old Apr 29, 2011 | 08:50 PM
99tegjawn's Avatar
im having a similar problem my cylinder 4 is misfiring and before that i had a cel that was related to the cat i need to replace that and the 02 sensors and hopefully that will do it
GaryTuesday
Jan 4, 2014 10:32 AM
92slamd-sedan
Sep 11, 2013 10:21 AM
DeucEG
May 2, 2010 11:41 AM
boarding2008
Sep 5, 2009 08:18 PM
delslow302
Mar 22, 2009 03:49 PM
