jdm gsr with type R cams, what kind of gains ?
Old Dec 31, 2006 | 05:34 PM
redDAinteg's Avatar
Default jdm gsr with type R cams, what kind of gains ?
What kind of gains can be made with type R cams on a jdm gsr(10.6CR) ? And will it be okay for boost ?
Old Dec 31, 2006 | 07:09 PM
lVlemphizStylez's Avatar
Default Re: jdm gsr with type R cams, what kind of gains ? (redDAinteg)
its fine for boost...Gains wont be much without a tune...
Old Dec 31, 2006 | 09:32 PM
redDAinteg's Avatar
Default Re: jdm gsr with type R cams, what kind of gains ? (lVlemphizStylez)
im talking about with a tune.
Old Dec 31, 2006 | 09:48 PM
the gains will be noticeable..i run ctr cams in my car (00-01 ITR Spec)
Old Jan 1, 2007 | 12:51 AM
redDAinteg's Avatar
have you any kind of dynos to compare in whp and wtq ?
Old Jan 1, 2007 | 07:01 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">have you any kind of dynos to compare in whp and wtq ?</TD></TR></TABLE>
When dynocenter.com was functional, there was a 96 GSR with an ITR intake cam (p/n 14111-P73-J00) and stock GSR exhaust cam. The intake cam with adjusted cam gears yielded an 11 WHP gain. There was a torque deficiency from 4400 RPM to 4800 RPM on that setup because the VTEC engaged too early. Otherwise, the ITR torque curve was better than the GSR throughout the RPM range.
Old Jan 1, 2007 | 11:20 AM
redDAinteg's Avatar
Default Re: jdm gsr with type R cams, what kind of gains ? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
When dynocenter.com was functional, there was a 96 GSR with an ITR intake cam (p/n 14111-P73-J00) and stock GSR exhaust cam. The intake cam with adjusted cam gears yielded an 11 WHP gain. There was a torque deficiency from 4400 RPM to 4800 RPM on that setup because the VTEC engaged too early. Otherwise, the ITR torque curve was better than the GSR throughout the RPM range.</TD></TR></TABLE>
wow
Old Jan 1, 2007 | 11:28 AM
mtny's Avatar
Good info Dogginator.
Old Jan 1, 2007 | 11:42 PM
DC4 me's Avatar
Default Re: jdm gsr with type R cams, what kind of gains ? (mtny)
does putting in ITR/CTR cams in a gsr still allow you to pass smog?
Old Jan 1, 2007 | 11:46 PM
Fat Chick Magnet's Avatar
ctr intake
itr exhaust
about 5hp gain.
Old Jan 2, 2007 | 08:10 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: jdm gsr with type R cams, what kind of gains ? (lghnea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lghnea &raquo;</TD></TR><TR><TD CLASS="quote">does putting in ITR/CTR cams in a gsr still allow you to pass smog?</TD></TR></TABLE>
I never had any problem with the sniff test. Heck, I even passed the OBDII dataport scan with my chipped P72. (Yes, it is OBDII with p/n 37820-P72-A02.)
Old Jan 2, 2007 | 08:19 AM
iH8RICERZ's Avatar
Yes sir..... my high mileage motor with intake, intake manifold, ctr intake cam, cam gears, header, exhaust passed about 5 months ago. No problems what so ever....
Old Jan 2, 2007 | 08:46 AM
cybergreencivic's Avatar
they would be ok for boost, but running your GSR's you have would be better for a turbo'd car. when i had my boost'd EG, i sold the ITR's i had for GSR's and it ran better. easier to tune as well.
Old Jan 2, 2007 | 12:26 PM
doood's Avatar
been there done that
Default Re: (cybergreencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cybergreencivic &raquo;</TD></TR><TR><TD CLASS="quote">they would be ok for boost, but running your GSR's you have would be better for a turbo'd car. when i had my boost'd EG, i sold the ITR's i had for GSR's and it ran better. easier to tune as well. </TD></TR></TABLE>
you would have made more power with the itr's
Old Jan 2, 2007 | 02:17 PM
i actually gained by ditching them. couple thread below from a quick search on why. maybe it was my tuner, but you dont loose going GSR cams on turbo.
https://honda-tech.com/zerothread?id=688993
https://honda-tech.com/zerothread?id=665359
https://honda-tech.com/zerothread?id=378242
Modified by cybergreencivic at 3:56 PM 1/2/2007
Old Jan 2, 2007 | 09:06 PM
DC4 me's Avatar
what kind of power would you be making if you also threw in some ctr or itr pistons along with the ctr or itr cams?
Old Jan 2, 2007 | 09:10 PM
DC4 me's Avatar
Default Re: (lghnea)
and would ctr cams make more power in the gsr than the itr cams?
Old Jan 3, 2007 | 02:54 PM
AW's Avatar
AW
I made 181 hp to the wheels with 01 ITR cams, skunk manfiold , mugen header, test pipe, greddy pe exhaust, cam gears and p08 skunk chip and VAFC tuned.
Old Jan 9, 2007 | 12:02 AM
DC4 me's Avatar
Default Re: (AW)
it seems like people only do the intake cam upgrade on the gsr motor. Does anyone know why this is so? Im saving up for cams on my gsr, (either itr/ctr) but if i should only do the intake cam, then that'll save me lots of money. what do you guys think?
Old Jan 9, 2007 | 04:59 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lghnea &raquo;</TD></TR><TR><TD CLASS="quote">it seems like people only do the intake cam upgrade on the gsr motor. Does anyone know why this is so? Im saving up for cams on my gsr, (either itr/ctr) but if i should only do the intake cam, then that'll save me lots of money. what do you guys think?</TD></TR></TABLE>
The reason that they only do the intake cam is because it provides about 11 whp and the exhaust provides about 3 whp. I installed both cams and the ITR valve springs. (GSR intake valve springs = ITR exhaust valve springs.)
There are better options for power now than the Honda cams. I installed my cams in 2000, when the aftermarket options were few and of questionable quality.
Old Jan 9, 2007 | 09:33 AM
redDAinteg's Avatar
Default Re: (Dogginator)
There are better options for power now than the Honda cams. I installed my cams in 2000, when the aftermarket options were few and of questionable quality.</TD></TR></TABLE>
well for me, this is going to be a boost application. So aftermarkets really isnt mush of an option. Wow I think i'll be pickin up just an intake cam from an itr or ctr and boost it.
Old Jan 9, 2007 | 10:32 AM
01DC4's Avatar
ITR cams are great for boost way better than gsr but i thought ctr cams were for more of a NA application
Old Jan 9, 2007 | 10:54 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (01DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01DC4 &raquo;</TD></TR><TR><TD CLASS="quote">ITR cams are great for boost way better than gsr but i thought ctr cams were for more of a NA application</TD></TR></TABLE>
Keep in mind that there are two versions of the ITR intake cams. The latest one (p/n 14111-P73-J01) used on the 00-01 USDM ITRs is quite similar to the CTR intake cam. The 97-98 USDM ITRs used p/n 14111-P73-J00.
sinister357
Sep 14, 2007 10:57 AM
NA JDM GSR
Oct 10, 2006 07:29 PM
G-Phi
Apr 16, 2006 01:14 AM
boostedeg22
Dec 28, 2004 05:26 PM
97jrscgsr
Nov 29, 2003 07:00 PM
