which cam should i use for set up
i'm running a jg pro ser head right now with stock b16 cams.i want to upgrade wondering which set to use i have a jdm itr intake cam/gsr exhaust or should i use gsr intake and exhaust cam and it is a 84mm ls block.tried search did not find the correct info help needed
Re: which cam should i use for set up (boostedeg22)
Is this Carl?
I'd run R cams, thats what I plan on.
Since you're looking for huge hp the R cams have done very well on some members high hp cars. Boostfed, etc...
Re: which cam should i use for set up (ReDHaTcHy97)
No, he means the ITR cams. ITR cams make more power than GSR cams. The benefits you get from a bunch more lift and duration FAR exceed any small loss from an extra degree or two over overlap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeg22 »</TD></TR><TR><TD CLASS="quote">only thing i only have the itr intake cam not the exhaust</TD></TR></TABLE>
That will work brotha Just use a GSR exhaust cam.
Re: which cam should i use for set up (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">That will work brotha Just use a GSR exhaust cam.</TD></TR></TABLE>
That is true, the GSR exhaust and the ITR exhaust cams are the same.... the ITR intake cam is very good for boost. I have seen alot of people make good power just by upgrading that one cam. I think Boostfed on here made over 30whp more with swaping the B16 cams for the ITR cams..... thats what I am going to be running also
Re: which cam should i use for set up (BoostedEG6)
if the itr cams are better then why do i see people using them for boost on cars making over 500hp...... i know the one car turbodcx(brian) built is using a type r head with gsr cams .. i've always hear that gsr cams were better for turbo setup's
Vtecme92
10-15-2005 07:53 PM
