power output.
ok i know this question has been asked a thousand times before but i want a good opinion before i spend thousands of dollars to be disappointed. so im building my gsr. i plan on using:
jdm itr pistons .25mm over size
buddy club spec V cams, springs, retainers
buddy club p1 racing valves
full port and polish
upgraded fuel system (full rail, injectors, etc.)
12:1 compression (2 layer head gasket)
100 octane
bitchin tune
i havent decided i want to do with the crank or connecting rods yet. any ideas for those? wat kind of numbers can i get out of that. i want close to 250 to the wheels.
100 octane
bitchin tune
have the stock crank balanced and micropolished. use stock rods with arp rod bolts since you're still using oem pistons. and dont forget to have the rods shaved to fit the itr pistons.
I'm no expert when it comes to cam selection but look into those cams a bit more. I think the BCV might be to aggresive for your setup.
And like doood said 250whp is not going to happen with that setup. You would need to PP the head, bore, stroke, and increase the compression along with using good quailty paired parts with a great tune.
Ali
Ali
Just to give you an idea this is a setup that put down around 230whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">
85mm bore
89mm stroke
Carrillo Rods
Wiseco +2cc pistons (11.6:1)
RLZ Stage 3 head
RLZ Stage 3 cams
RLZ Single valve springs
JG Intake manifold
Stock ITR TB
Mugen intake
RC 370cc injectors
AN-R header with 3" collector
Thermal 3" exhuast
ATS 4.9 FD
Clutch Masters stage 3 clutch
Toda flywheel
Toda timing belt
Toda cam gears
Drive Shaft Shop stage 3 axles
AEM EMS
85mm bore
89mm stroke
Carrillo Rods
RLZ Stage 3 head
RLZ Stage 3 cams
JG Intake manifold
Stock ITR TB
Mugen intake
RC 370cc injectors
Thermal 3" exhuast
ATS 4.9 FD
Toda flywheel
Toda timing belt
Toda cam gears
AEM EMS
xbigpitax
12
Jul 22, 2011 12:34 PM
Honda_Fanatic
Apr 23, 2008 07:25 AM
