Car wont crank need serious HELP
Old Dec 31, 2006 | 02:16 PM
import810's Avatar
Default Car wont crank need serious HELP
Last night I swapped my motor back into my gsr and I started it up and drove it down the street and back. I pulled in the garage shut it off and now it wont even crank.
Things I have checked:
Harness Plugs
ECU
Starter
Battery
Alternator
Grounds
There is a clicking noise when I try to start it from a relay, but its NOT the main relay. Is this a problem?
Please help me I need this car running tonight!
Old Dec 31, 2006 | 02:35 PM
da_33's Avatar
Default Re: Car wont crank need serious HELP (import810)
it could be the ignition switch
Old Dec 31, 2006 | 02:38 PM
import810's Avatar
Default Re: Car wont crank need serious HELP (da_33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_33 &raquo;</TD></TR><TR><TD CLASS="quote">it could be the ignition switch</TD></TR></TABLE>
how do I test it?
Old Dec 31, 2006 | 02:57 PM
DS002's Avatar
Banned
how did you test the starter ? try cranking it and hit it with a hammer
Old Dec 31, 2006 | 03:25 PM
import810's Avatar
Default Re: Car wont crank need serious HELP (DS002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DS002 &raquo;</TD></TR><TR><TD CLASS="quote">how did you test the starter ? try cranking it and hit it with a hammer </TD></TR></TABLE>
I hit it multiple times and doesnt even crank. I took the starter to Kragen and they said it was fine. The main relay clicks after I turn the ignition to start. I have no idea what to do next.
Old Dec 31, 2006 | 05:05 PM
import810's Avatar
bump I need answers please please please
Old Jan 3, 2007 | 06:47 AM
ckyfan87's Avatar
I could be your clutch engagement switch. Get under your dash and take it out of the screw whole. Push it in while you crank it and see if that works? I had the same problem.
Old Jan 3, 2007 | 10:38 AM
butand50's Avatar
My buddie had a similar problem wit his CRX. When i went over to help em out, it turned out there was just to much corrosion on the positive battery cable clamp. Not sure thats whats your problem is, but go disconnect the cable and run some sand paper around the inside of it.
Old Jan 3, 2007 | 12:03 PM
SimplyB18C1's Avatar
I second the terminal theory. It's surprising sometimes how something so little on our cars can be overlooked . I spent a whole day troubleshooting a problem simliar to this and come to find out It was just a corroded terminal on the positive side. Try It. You might be surprised. Good Luck.
Old Jan 3, 2007 | 12:07 PM
import810's Avatar
Default Re: (SimplyB18C1)
found the problem. I grounded my tranny ground to the engine bay, but it was not grounding right because of the paint. I scraped off the paint and WALA it started like a magical fairy. But really thats what happened.
Old Jan 3, 2007 | 12:19 PM
benjaminenjamin's Avatar
Default Re: (import810)
it always sucks when you scratch your head for days over the complicated things, and then its a simple solution. glad its back on the road for you.
Old Jan 17, 2007 | 08:55 PM
92integraVTECgsr's Avatar
Default Re: (benjaminenjamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import810 &raquo;</TD></TR><TR><TD CLASS="quote">found the problem. I grounded my tranny ground to the engine bay, but it was not grounding right because of the paint. I scraped off the paint and WALA it started like a magical fairy. But really thats what happened.</TD></TR></TABLE>
Im hoping thats my problem.. im having the exact same problem with my friends swap right now..
b18cEK
21
Apr 9, 2014 07:14 PM
efhondaracer27
Jan 21, 2010 10:32 AM
uneek4dr
Honda Civic (2001 - 2005)
Dec 2, 2007 09:12 AM
LSracing94
Nov 25, 2005 10:23 PM
turboxsi
Jan 29, 2004 01:33 PM
