96 civic dx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek gripper »</TD></TR><TR><TD CLASS="quote">A 96 dx is an EJ.</TD></TR></TABLE>
True. That whole chassi (96-00) is generally referred to as an EK. Whatever works for you.
Technically it's neither, but the 96-98 models are generally referred to as EK's, 92-95's are generally referred to as EG's, and the 99/00 Si's are generally referred to EM1's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Technically it's neither, but the 96-98 models are generally referred to as EK's, 92-95's are generally referred to as EG's, and the 99/00 Si's are generally referred to EM1's.</TD></TR></TABLE>
That doesn't make sense. You're telling him it's not an EK, when you said 96-98 Honda Civics are generall called EKs when he has a 96.. Hmm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote">so then what is a 99-00 ek dx lx hx </TD></TR></TABLE>
Again, generally any 96-00 is referred to as an EK as a broad term. To get specific, a coupe is an EJ, a hatch is an EK; I'm not sure about ferios. 99-00 Si modles are typically called EM1 because of the motor that the car comes stock with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">That doesn't make sense. You're telling him it's not an EK, when you said 96-98 Honda Civics are generall called EKs when he has a 96.. Hmm.</TD></TR></TABLE>
It makes perfect ******* sense.
You know exactly what the expletive I meant but for some ungodly reason you feel it's necessary to be an ******* about everything.
At OP:
In general, 96-98 civics are referred to as EKs in general, regardless of their actual chassis code.
I'll just leave it at that.
At OP:
At OP:
I'll just leave it at that.</TD></TR></TABLE>
Care to get that sand out of ****? You seem to be getting butt hurt over nothing.
Let's analyze this again, mmkay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Technically it's neither, but the 96-98 models are generally referred to as EK's</TD></TR></TABLE>
The OP has a 1996 Honda Civic coupe. Specifically, 92-00 coupes with the exception of the 99-00 Si is referred to as an 'EJ'. Generally 96-00 Civics are referred to as 'EK', however this is a broad term. You're saying it's neither an EJ or an EK, so what is it than if it's a 1996 coupe? You said it can't be an EJ or an EK? Care to explain?
Modified by JDM-EJ1 at 4:16 PM 12/31/2006
At OP:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboi07 »</TD></TR><TR><TD CLASS="quote">God.....I've started a war...
Not at all. What Syndacate posted doesn't make any sense. I want to make sure he understands what he's talking about so he doesn't give others misinformation.
</TD></TR></TABLE>Not at all. What Syndacate posted doesn't make any sense. I want to make sure he understands what he's talking about so he doesn't give others misinformation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboi07 »</TD></TR><TR><TD CLASS="quote">So ok. So my 96 dx coupe d16y7 non vtec is a...</TD></TR></TABLE>
EJ. I'm not sure specifically what the last number is. For example, my 1994 Honda Civic EX coupe is an EJ1. 96-00 EX coupes are EJ8. It will say in your VIN number what your car is.
