Vtec doesnt kick in
Old Dec 31, 2006 | 01:54 PM
gerrylla's Avatar
Default Vtec doesnt kick in
I have a 93 EG with a GSR swap but my Vtec wont kick in and i am not getting any check engine lights for it, have any idea what it is?... I am thinking its the solenoid but theres no check engine light for it
Old Dec 31, 2006 | 01:55 PM
bart2546's Avatar
Default Re: V-Tech doesnt kick in (gerrylla)
Check to make sure you have enough oil, if the oil pressure isn't right it won't kick in. Also, just to prepare you for the death, it's VTEC, not V-TECH, you're about to receive a lash.
Old Dec 31, 2006 | 01:59 PM
Tippyman's Avatar
Get a new phone.
/lash
Old Dec 31, 2006 | 02:00 PM
InvaderTrax's Avatar
You should have gotten the BestBuy extended warranty...
Han Solo's Avatar
Default Re: V-Tech doesnt kick in (bart2546)
you do realize that V-TECH doesnt mean anything?? ITS VTEC, its on your ******* valve cover how do you mess it up???
Old Dec 31, 2006 | 02:20 PM
cherryhatch00's Avatar
Yea ..pretty much what dude said earlier, check your oil ..oil pressure, then the wiring to your solenoid. Something could've come loose or.. well, you have no oil.
Old Dec 31, 2006 | 02:21 PM
Turbo_y8's Avatar
Default Re: (cherryhatch00)
on a serious note. is you oil pan dented?
pick up slightly clogged?
windage tray have build up?
Old Dec 31, 2006 | 06:03 PM
gerrylla's Avatar
Yea my oil pan is dented and i need a new gasket for it
Old Dec 31, 2006 | 06:04 PM
gerrylla's Avatar
I was typying fast as hell cuz i had just finished swaping out my tranny and i was trying to get a quick reply to fix it
Old Dec 31, 2006 | 06:07 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (gerrylla)
https://honda-tech.com/zerothread/1812135
Old Dec 31, 2006 | 06:08 PM
trrbl1bmx's Avatar
For future reference the SEARCH button is your only friend on HT, especially when you can't spell vtec. But here this link has everything you need to know straight from the manual. I sourced this through the search button, by typing in " vtec doesn't work " and clicking "archived content" and then clicking "Seach" and resulted 289 results! This being most recent!
https://honda-tech.com/zerothread?id=1812135
Old Jan 1, 2007 | 10:26 AM
Turbo_y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gerrylla &raquo;</TD></TR><TR><TD CLASS="quote">Yea my oil pan is dented and i need a new gasket for it</TD></TR></TABLE>
well there is your problem
get a new/used non dented pan.
Old Jan 1, 2007 | 10:43 AM
GreenEHDriver's Avatar
Default Re: (Turbo_y8)
http://www.leecao.com/honda/vtec/index.html learn about vtec
Old Jan 1, 2007 | 11:17 AM
Sean @ ESG's Avatar
my cordless vtech doesn't work sometimes if I get too far away from the dock.
Old Jan 1, 2007 | 12:34 PM
cambopheonix56's Avatar
What ecu do you have?
Old Jan 2, 2007 | 02:15 PM
gerrylla's Avatar
Default Re: V-Tech doesnt kick in (cambopheonix56)
I am running a p72, i changed the solenoid, rewired it, and changed the oil...and still nothing????
Old Jan 2, 2007 | 02:19 PM
Malakai's Avatar
its prob ur dented pan. Lot o people say it wont work if the pan is dented.
Old Jan 4, 2007 | 08:27 PM
Default Re: (Malakai)
i dont think its your pan thats the problem is the vtec soleniod pluged in correctly? and what harness are u using?
Old Jan 4, 2007 | 08:35 PM
em1electron69's Avatar
Default Re: Vtec doesnt kick in (gerrylla)
um is your name gabriel. oh ok
Old Jan 4, 2007 | 08:37 PM
Midori Green's Avatar
Default Re: Vtec doesnt kick in (em1electron69)
Lesson # 1 Never say V-Tec again... VTEC how hard is it its all over the site!
Old Jan 4, 2007 | 10:59 PM
mc_civic213's Avatar
is the vtech plug in
Old Jan 4, 2007 | 11:17 PM
hmtcrxsir's Avatar
Default Re: (mc_civic213)
could be numerous things. oil level is low. oil pan dented. plugs not plug in. vtec wire melted?
Old Jan 5, 2007 | 07:26 AM
djsire's Avatar
Default Re: (hmtcrxsir)
hey douche bag
read my sig. and good luck.
mine turned out to be a dented oil pan. threw no codes
Old Jan 5, 2007 | 07:42 AM
Syndacate's Avatar
Probably ******* oil pressure...like the FIRST POST said...that's what I'd check first, get a new oil pan..****...VTEC problems aren't that complex...
nomoracin1030
Mar 31, 2019 07:47 PM
that_sick_eg
Jan 19, 2011 07:05 PM
jordan_rael_420
Sep 17, 2008 04:07 PM
da9driver
24
Aug 25, 2005 01:00 PM
stringcheese840
Jun 22, 2005 02:28 PM
