Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Question: Stack oil sandwich Adapters
Old Dec 31, 2006 | 01:15 PM
creechrr's Avatar
Default Question: Stack oil sandwich Adapters
I recently installed an oil cooler on my D16Z6. I occasionally take part in open track events and have a need for addtional oil cooling as the car is boosted.
I was originally using one oil filter sandwich plate as a source for oil feed to the turbo and a signal source for both oil pressure and oil temp gauges. While installing the oil cooler, which uses an additional Mocal sandwich plate, I ran into clearance problems with the fittings that attach the lines to the sandwich plate.
I ended up adding a third plate into the mix to gain enough space for the line to attach to the Mocal adapter without clearance problems.
So, now I am running:
1) sandwich adapter - oil pressure/oil temp sending units
2) turbo oil feed - this actually ended up being a more direct attachment point. Better routing.
3) Mocal - oil cooler lines
Do you guys think this is too much weight to be hanging off the back of the block?
Old Dec 31, 2006 | 01:36 PM
vtecjj's Avatar
Default Re: Question: Stack oil sandwich Adapters (creechrr)
No, because each sandwich plate is attached to the threaded fitting (where the oil filter would normally screw onto) and not onto the block itself. Unlike where the stock oil pressure sender is threaded onto-that is attached to the block itself.
The sandwich plate/oil filter threaded fitting can support that weight. How do I know? Because I too have a stacked sandwich plate set-up. I have a Golden Eagle LS/vtec sandwhich plate, mated to a greddy oil cooler sandwich plate and haven't had any problems.
The only issue you might have is whether or not you'll be able to get the oil filter up in there (assuming you're not using a remote location) from the bottom since your stack of sandwhich plates might be too long.
Old Dec 31, 2006 | 02:05 PM
creechrr's Avatar
Default Re: Question: Stack oil sandwich Adapters (vtecjj)
There's still plenty of room for the filter.
Thanks.
Anyone else?
Old Jan 1, 2007 | 08:49 AM
creechrr's Avatar
Bump
Old Jan 1, 2007 | 02:25 PM
BrianZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creechrr &raquo;</TD></TR><TR><TD CLASS="quote">Bump</TD></TR></TABLE>
You should read the forum rules - here is a link https://honda-tech.com/zero...85345
- No bumping. Makes a mess out of things. If the topic isnt active enough to stay on the first page, it probably wasnt that interesting anyways.
Old Jan 2, 2007 | 08:03 AM
Andrie Hartanto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote">No, because each sandwich plate is attached to the threaded fitting (where the oil filter would normally screw onto) and not onto the block itself. Unlike where the stock oil pressure sender is threaded onto-that is attached to the block itself.
The only issue you might have is whether or not you'll be able to get the oil filter up in there (assuming you're not using a remote location) from the bottom since your stack of sandwhich plates might be too long.</TD></TR></TABLE>
John,
why would you run it this way? Take the golden eagle sandwich plate out, get a T-fitting or drill a new hole onto the other sandwich plate and tap it. Run the line through there.
Old Jan 2, 2007 | 08:37 AM
vtecjj's Avatar
Default Re: Question: Stack oil sandwich Adapters (Andrie Hartanto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">
John,
why would you run it this way? Take the golden eagle sandwich plate out, get a T-fitting or drill a new hole onto the other sandwich plate and tap it. Run the line through there. </TD></TR></TABLE>
good point. I'm going to have to re-examine my set-up
Old Jan 2, 2007 | 09:09 AM
creechrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote">good point. I'm going to have to re-examine my set-up </TD></TR></TABLE>
Do you have any fitment issues clearing the block and surrounding brackets with the Greddy oil cooler adapter?
Old Jan 2, 2007 | 10:08 AM
Vitt1's Avatar
I don't mean to hijack the thread but I have a related question. I just tried installing a sandwich plate on a GSR yesterday and ran into clearance problems too. I was wondering if taking out the GSR stock oil cooler will give me better clearance. Or are the only solutions stacking plates, OR using a spin-on adapter and remoter filter? Or are there any adapter fittings that might make it work?
thanks
Old Jan 2, 2007 | 02:04 PM
creechrr's Avatar
Default Re: Question: Stack oil sandwich Adapters (Vitt1)
So far, stacking is working for me.
Removing the stock "oil cooler" is going to put you closer to the block. That may lead to addtional clearance problems.
hndacord02
May 30, 2010 07:23 AM
SolAssassin
Oct 19, 2007 11:57 AM
redlineintegra
Jun 10, 2004 03:00 PM
Spade
Mar 15, 2002 06:36 AM
