h22a turbo?
Old Dec 31, 2006 | 10:49 AM
hondaaccord94's Avatar
Default h22a turbo?
i need some major help fellas,i got my car back yesterday from my tuner he just street tuned it for 3-4hours it ran fine for about 1hour and after that it started breaking up in high rpm's(6k),then it turns off while im driving i check and it was spark plug wire that jumped of the distributor,i fix that now the car won't start at all i keep trying and it starts so i start driving home and it starts overheating,so i turn it off for about 35min,then try to turn it on and it won't so i keep trying and trying and then it comes on and i drove home.so who can help me with this problem.
its a built h22
tuned on hondata s300.
Old Jan 1, 2007 | 06:35 AM
Default Re: h22a turbo? (hondaaccord94)
anyone?
Old Jan 1, 2007 | 08:39 AM
prelude2perfect's Avatar
I dont know whats wrong, but I can tell you this for sure - STOP DRIVING YOUR CAR BEFORE YOU KILL IT!!! Tuning is the NUMBER ONE thing that needs to be done correctly on your car. I would never trust a street tune on my car, DYNO DYNO DYNO!
Old Jan 1, 2007 | 11:05 AM
matt56's Avatar
Default Re: h22a turbo? (prelude2perfect)
Street tuning can be fine as long as it was done using a wideband and the guy knows what hes doing. now with the over heating, has it ever over heated in the past? go through all the basics like coolent level, check for leaks ect... and for the breaking up at high rpm's i would get ahold of your tuner and explain exactly what its doing before you drive your car anymore and see what he says about it and recomends you do.
Hope it turns out to just be somthing simple for you, Good luck
Old Jan 1, 2007 | 11:08 AM
turbociviccoupe's Avatar
i just dynoed my car and i had the same problem. but i blew the head gasket on the dyno so when the cylinder started to fill up with steam the car would overhead and wont start. if i let it rest it will start up again but die after a few minutes. do a compression and a leak down test.
Old Jan 1, 2007 | 03:25 PM
Default Re: h22a turbo? (turbociviccoupe)
im not driving my car now.
thats what probably happened a blown head gasket,thats what i thought it was.
i'm gona check over the car tomorrow and talk to my tuner.
eriki
Apr 6, 2013 10:53 PM
eg:R
Engine Management and Tuning
Dec 27, 2011 07:13 PM
mgags7
14
Sep 26, 2005 07:41 PM
espanol
Jan 23, 2003 04:49 AM
MotorMatrix.com
Jan 13, 2003 07:11 AM
