noob question - Intake + Exhaust + water leak
Car is a stock 99 Civic EJ6, got it second-hand.
If I get a new intake (and later exhaust) will I need to get the car tuned for fuel injection (or something)?
Also, my car sounds a little different then it used to when I start up, I spotted a tiny drip coming from under the car after driving and it's water (room temp, not hot or cold). I see moisture stains on some of the metal struts on whatever system is located to the UPPER LEFT of my engine block, probably related to my radiator? I don't know but there's a plug there that looks "sort" of like what a dipstick looks like, there seems to be moisture/grime all around the cap area and I'm not sure what that is. None of the hoses seem to be cracked.
Help me, i'm a noob, waiting on amazon for my tech manual.
If you still have A/C in the car, I would say it's either the normal condensation from the A/C system or the A/C system could be leaking its refridgerant in a couple places.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mitsu »</TD></TR><TR><TD CLASS="quote">Car is a stock 99 Civic EJ6, got it second-hand.
Help me, i'm a noob, waiting on amazon for my tech manual.</TD></TR></TABLE>
No it does not have to be tuned. If you truly live in Hawaii then I'm going to go on the assumption of my personal experiences where it's very moist there... It's probably just condensation, I wouldn't worry about the water - IF IT SMELLS like water...unless you guys use straight up water in your coolant systems instead of anti-freeze due to no chance of freezing...then it's possible it could be a coolant leak.
Though one thing at a time.
Next time you do that, and you look under your car and you see a leak. Look from ABOVE the engine and try to find out where the water came from. Ie, the head, the block....the spark plugs or battery?? Wherever it's comin from, try to find out, that's probably most important.
Also, if it's hot out (like it is) - you probably have AC. The AC system in cars (like all AC systems) produces water as a bi-product of cooling the air. If you let a car sit w/ the AC on, the water drips...but that's perfectly normal.
As for the moisture stains. I'm having trouble figuring out what the expletive you are talking about - upper left of the engine block? Well from one angle there's a battery there, and from the other angle there's a PS reservoir. Neither have anything that resembles a strut in my opinion. So more descriptive help would be better to help you.
Yeah I still have my AC in. The area I'm talking about is below the battery, here's pics.
Maybe I'm paranoid, the water drip was light, like I wouldn't have noticed it if I hadn't become interested in my car. Could have been there forever. If you say it's nothing to worry about i'll let it go.
thats nothing to worry about at all.. that would be the transmission dipstick FYI. The "grime" you speak of around it is probably from the last time you got your trans serviced. The tech prob just spilled a little on top, over time building up dirt in the spilled fluid, creating that crap.. you can clean it off with parts cleaner or just wipe it with a rag if it bothers you.
Hey guys i swapped out my sohc on my 95 civic ex. i have the b18b with the b16 head. i got the head machined and had a valve job done. the block was good.... For some reason i have water coming out of my muffler. oh, and from the headers (where they connect to the piping.... any ideas on what it could be? i dont think the head is warped since it has just been machined.... the head gasket has been used 3 times but i have not ran the car. i copper sprayed it. the gasket was for the b16 head (dohc vtec) any ideas? i really need the help.
juevi
14
Aug 21, 2011 01:34 PM
