look at my turbo ITR project.
This is all that i have to show right now. the motor just got back from the machine shop and my builder is starting to put it back together. here are the mods
Garret T3/60-1 turbo
AFI exhaust manifold
AFI down pipe
AFI dumptube
2.5" intercooler piping
front mount intercooler
oil plate
half sized radiator
high speed 12 in slim fan
CP forged 81.5mm 9.0:1 pistons
Eagle H-beam rods w/arp bolts
OEM lower gasket kit
Blox boostgauge
Blox oil temp gauge
Blox oil pressure gauge
ARP headstuds
Thermal 3" catback
Apex-i AVCR boost controller
Tial 50mm BOV with 11lb spring
Tial 44mm wastegate with 10lb spring
RC 750 saturated injectors and clips
Supertech dual valve springs and retainers
Walbro 255lhp feul pump
3 bar map sensor
Neptune
P28 ecu
head work/3 angle valve job
hone and bore 20 over
OEM uppergasket kit
OEM Timing belt
OEM water pump
OEM bearings and washers
ACT 6 puck clutch
CTR intake cam and stock ex.
AEM fuel rail and pressure reg.
on to the pics
i will keep you guys updated and post more pics as this finishs up. should be getting it tuned on the 13th of this month.
feel free to comment
AFI down pipe
AFI dumptube
oil plate
half sized radiator
Blox boostgauge
Blox oil temp gauge
ARP headstuds
Thermal 3" catback
3 bar map sensor
Neptune
P28 ecu
OEM uppergasket kit
OEM Timing belt
OEM water pump
ACT 6 puck clutch
on to the pics
i am shooting for around 350-400whp on about 15-18 psi. as soon as i get more pics and the dyno tune up, I will post them. do you think that i can reach my goal?
nice set-up
