cant get my cel to work need help badly
Old Dec 30, 2006 | 04:54 PM
b18bcrxhf's Avatar
Default cant get my cel to work need help badly
i just did a swap and the car had no bulb for the cel so i put a new bulb in and tried unplugging some sensors and nothing i do makes the light come on. i cant read codes either... im also having troubles getting my speedo to work ive checked grounds and fuses could the computer be causeing these problems? what could possibly causing my cel not to work
Old Dec 30, 2006 | 08:41 PM
b18bcrxhf's Avatar
bump for some advise
Old Dec 31, 2006 | 11:01 AM
b18bcrxhf's Avatar
bump for startin my new year off with a check engine light
Old Dec 31, 2006 | 11:13 AM
bart2546's Avatar
Default Re: (b18bcrxhf)
First thing I'd check is when you first start the car or turn it to the "on" position without starting it, the CEL should come on. Is it doing that? If not maybe try one more buld, if you're sure the bulb is good then I'd say year you're ECU may not be sending information/power to it. Since the speedo's are also now electronic check the VSS to make sure it's connected and installed properly. But if the ECU is messing something up for the CEL it may also be screwing that for you too but I'd start with the VSS with that.
LaOXXKIDD
Aug 22, 2009 05:42 AM
D16SohcVtec
Apr 10, 2009 09:44 PM
beeroh
Sep 24, 2004 08:16 AM
LSpimpTEC
Jul 29, 2004 09:09 PM
95LSS
Mar 7, 2004 11:00 AM
