car randomly dieing
i just swapped a jdm b16 into my 93 eg, and it started up fine. so i left it outside for about 2 weeks waiting on some parts, then i try to start it, all i got was cranking, so i checked spark plugs, i took one them ou connected to a spark wire, laid it on something metal to check for sparks, it had none. so checked ground and cleaned the distributor, and then it had spark. so i put everything back and tried to start it up, it did, but when i took it out for a drive, the whole died on me, so i let it idle and it died. i'm thinking bad distributor???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish »</TD></TR><TR><TD CLASS="quote">
this subject is extremely broad ftw</TD></TR></TABLE>
true...I would start off by swapping out the entire distributor hopefully solving all possible problems caused by the ignitor, coil....and if that doesn't solve it then I would move on to any possible fuel issues...is your car equipped with an alarm?
Travis Davidson
Jul 3, 2024 05:20 PM
