Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
how hard springs on a ITR????
Old Dec 30, 2006 | 07:22 AM
Tricid's Avatar
Default how hard springs on a ITR????
Hey guys
im going to uppgrade my coilovers now, running on K&W V2 and thier springs(9k fr / 6k rear). Im going to buy the Spoon Adjustable Damper Kit thats for sure.
My question to you is which springs do you run on(I drive as much as I can on tracks nevermind the DD, that i dont care of). A-J racing recpmmend 18kg front 16kg rear feels quite hard. so what is your opinion???
emanuel
Old Dec 30, 2006 | 12:58 PM
Todd00's Avatar
I said I don't want a title!
Default Re: how hard springs on a ITR???? (Tricid)
1000 lb in the front and 900 rear. Ok I guess, it would make for a pretty neutral setup.
Or if you wanted more oversteer, you could always try something like 800ft 1000rear.
I personally wouldn't daily drive with either setup if this car is your only car. I'd run a compromise setup like 600/800, which would still be approaching the limits of civility.
Old Dec 30, 2006 | 03:19 PM
Tricid's Avatar
im not planing to go for a civility dd. as for now i can say that im not happy with its stiffness. I want it to be so hard it can get with original bushings....
Old Dec 30, 2006 | 05:35 PM
Todd00's Avatar
Default Re: (Tricid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tricid &raquo;</TD></TR><TR><TD CLASS="quote">im not planing to go for a civility dd. as for now i can say that im not happy with its stiffness. I want it to be so hard it can get with original bushings....</TD></TR></TABLE>
That's because you're only running 500ft/330r lb springs right now.
But 'hardness' has a much to do with shock valving as it does springrates. Instead of focusing on stiffness, focus on making a great handling car. 600/800 is a fantsatic setup if you are running oem bushings, no cage and sticky street tires.
Without a cage I presonally would not run any spring over 1000 lbs.
Old Dec 30, 2006 | 07:15 PM
PrinceAli132's Avatar
Default Re: (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Without a cage I presonally would not run any spring over 1000 lbs.</TD></TR></TABLE>
Im not trying to question your comment but was just wondering why you feel that running over 1000lb spring rates are not good?
I'm not trying to disagree with you or anything but just asking in the interest of learning.
Ali
Old Dec 31, 2006 | 01:12 PM
Todd00's Avatar
Default Re: (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">
Ali</TD></TR></TABLE>
I don't know just how much the ITR chassis will handle sans rollcage (rumors are around 1000lb), but once you start running incredibly high springrates the chassis starts flexing instead of letting the suspension do the work. And that's not good.
Old Jan 6, 2007 | 04:05 AM
Tricid's Avatar
anyone else? someone must use his teg on the tracks? what setup do you have??? cheers
Old Jan 6, 2007 | 09:23 PM
Gedupsound's Avatar
a friend of ours runs mugen coil overs, im not sure the exact spring rates, but i believe its in the range of 1100lb fronts and 900 rears.
typer0853
11
Apr 28, 2005 03:59 PM
Ex-ITR5874
Aug 22, 2004 04:00 AM
96hb
Apr 20, 2004 06:41 PM
NINJASPY
Jun 24, 2003 12:55 PM
Doctor CorteZ
Mar 3, 2002 08:07 AM
