h22 Turbo EG???
im turboin my h22 in my 95 civic hatch with a t3/t4 70 trim and the turbo is rubbin on the altnator dose anyone no how to make it fit other than goin with a differnt manifold and if not then whats the best manifold that will give me enough room to work with??
I have a customer running the h22a in an EG chassis and we ended up using the Hasport motor mount kit with the EF altenator relocation kit. It relocates the altenator to where the AC compressor is at.
Drop me a PM if you need any of these parts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch59 »</TD></TR><TR><TD CLASS="quote">im turboin my h22 in my 95 civic hatch with a t3/t4 70 trim and the turbo is rubbin on the altnator dose anyone no how to make it fit other than goin with a differnt manifold and if not then whats the best manifold that will give me enough room to work with??</TD></TR></TABLE>
Do you have any pics of what your dealing with? What we did was put the compressor side on the radiator side and put a smaller alternator belt , and the dp actually fitted better this way with the oil pan and gave us better ground clearance .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch59 »</TD></TR><TR><TD CLASS="quote">so where do i get that relocation kit from??</TD></TR></TABLE>
http://www.explicitspeedperfor....html
i have the exact same manifold. the manifold is crap but i made good power on it. this is how close it was. i also made a alternator bracket to lower it.
what i did was change the alternator to an obd-2 one and the place where you plug it up is a little different. so it gives it a lttle more clearance.
you can make good power but the ssac manifolds crack sooner or later. hope that helps.
Fuzion
Sep 13, 2005 12:14 PM
