problem with em2
I was driving home from work and my ABS AND SRS lights came on and all my meters failed. My car was still fine. When i got home, i could not start my car. Does anyone know whats wrong?
If everything but the cluster works, run diagnostics on the gauge cluster.
Im assuming all of the meters failing to mean you have no tach, speedo and gas gauge, and not accessory gauges that you added.
If there's error lights on and no moving needles, I vote for cluster short out.
when i step ont he gas the battery light shows and the engine check light comes on...and my tranny is fucked up making wierd sounds and shaking the whole car..everything is messing up in one day..and yes i prolly need a new battery too..
that problem your having is very typical of a charging system problem. have your battery tested along with the charging system. (cluster short is very unlikely however possible, start with the charging system/battery)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01 EM2 »</TD></TR><TR><TD CLASS="quote">my transmission also makes sounds too..</TD></TR></TABLE>
automatic or manual? what kind of sounds, and when does the tranny make these sounds?
i just installed a new battery and everything is running fine and my transmission stopped making noises..but the battery light still pops up sometimes ..when i start my car and step on the gas
shot_them_all
Honda Civic (2001 - 2005)
Dec 6, 2011 04:43 PM
my92hondasucks
11
Jul 26, 2006 03:54 PM
wizzards581
Sep 22, 2002 10:34 AM
