plz help: hesitation problem
Old May 13, 2002 | 02:12 PM
Tripz's Avatar
New User
Default plz help: hesitation problem
when i get on the throttle, the car jerks/bogs (almost like a misfire) then pulls normally. i notice it more in lower rpms but the hiccup is there in all gears no matter what rpm im in when i step on the gas. Here are the things i have checked over the last few weeks.
-TPS sensor ok and within voltages
-tb is clean (adjusted throttle stop screw, idle screw->all ok)
-New spark plugs, checked ignition wires (even swapped with oem wires)
-new cap and rotor
-New knock sensor (old one broke loose at the connector)
-rebuilt distributer (also tried swapping distributers with a friend)
-tried swapping vacuum boxes but to no avail
-checked cat-> ok
-adjusted the fuel (bumped up the pressure then dropped it down)
-adjusted timing (advanced/retarded)
now i'm thinking it's maybe my 02 sensor but the sweep on my air/fuel gauge is responsive so maybe it's not. what else can i check? this problem is really annoying.. thanks!
91 Accord EX
jdm h22a
lsd tranny
Old May 13, 2002 | 05:18 PM
HXMan's Avatar
Default Re: plz help: hesitation problem (Tripz)
My car did that....I didn't have the O2 sensor signal wire grounded on one leg.
vtec93accord
Mar 23, 2008 05:42 PM
cjk95delsolsi
Oct 23, 2007 11:48 PM
Bustinvtec
May 30, 2006 01:19 PM
Bustinvtec
May 28, 2006 11:16 PM
B-serious
Mar 8, 2006 10:02 PM
