Results from my comp. test as well as reaching a new era
Old Dec 29, 2006 | 10:54 AM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Results from my comp. test as well as reaching a new era
Well, yesterday I got the minor ignition problem under control and my father and I went for a little cruise to grab some dinner. during our cruise, the R rolled 140,000 miles.. whoohoo!
anyways, this morning, i went ahead and did a compression test. Did it a couple times just to make sure and came up with the following. Yes, its a little low, regardless I was hoping for consistency, but didn't really get it. Here are the results:
190 - 140 - 140 - 200
I don't have a leakdown tester, but I feel that this is essential that I perform one. I had plans of doing a mild build this winter in hopes of it being ready for expo, but I'll have to see. Marc compiled a head package for me, which is very tempting. Since I am a full time student, I located a shop 7 miles from school which I am going to visit in a couple weeks and see what I can do.
the shop's site is here: http://www.stewartengines.com/
any suggestions or leads I am open to. was considering a mild head package with good tune, or a complete OEM head. I just hope whatever I choose I can be ready for expo
Old Dec 29, 2006 | 12:05 PM
RTW DC2R's Avatar
yeah those numbers arent the best. Did you complete the compression test with the engine warm? Did you happen to try the oil in the cylinder test? Did you check the valve lash? Do you burn a lot of oil? Does the car drive like crap and get poor gas mileage? If so I would definitely look into getting a leak down. 2 and 3 look pretty beat. It may just be the valves and might not be anything major. The leakdown should help you determine that.
I would determine exactly what the problem is before figuring out what route you want to take on the rebuild. You may simple need a valve job and some seals.
Old Dec 29, 2006 | 02:23 PM
rino924's Avatar
Community Builder
Default Re: (RTW DC2R)
thanks RTW. im currently looking for a leakdown tester so i can get this done.
hopefully its just something minor, but you never know with a motor that has this many miles
Old Dec 29, 2006 | 07:47 PM
rino924's Avatar
Community Builder
Default Re: (rino924)
after researching a little more, this looks like it could potentially be a head gasket issue. hopefully i'll have a leakdown tomorrow
Old Dec 29, 2006 | 07:58 PM
GO-FIGHT-KILL's Avatar
Ryan, what's the "Oil in the cylinder test", and "Valve lash test"?
I'm about to perform a compression test on my R, looking for some other tests to do while I'm at it. It's been feeling weird lately, and I'm finding a lot of black **** on the back of my car.
Old Dec 29, 2006 | 08:20 PM
rino924's Avatar
Community Builder
Default Re: (GO-FIGHT-KILL)
looked into valve lash a little bit. this is off the crane cams site. annoying to read with the question marks everywhere, but gives you an idea.
http://www.cranecams.com/?show=newsLetters&no=216
you say the car feels weird, why not a sixth gear?
Old Dec 29, 2006 | 09:07 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rino924 &raquo;</TD></TR><TR><TD CLASS="quote">you say the car feels weird, why not a sixth gear? </TD></TR></TABLE>
roffles
don't get he started again
Old Dec 29, 2006 | 09:27 PM
rino924's Avatar
Community Builder
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
roffles
don't get he started again </TD></TR></TABLE>
bah, you know i did that just to get him going. thought it would give him a bit of a laugh
Old Dec 30, 2006 | 03:16 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">Ryan, what's the "Oil in the cylinder test", and "Valve lash test"?
I'm about to perform a compression test on my R, looking for some other tests to do while I'm at it. It's been feeling weird lately, and I'm finding a lot of black **** on the back of my car. </TD></TR></TABLE>
dont quote me on this, but supposedly when doing a comp test, if you have shitty results, you can put a cap full of oil in the cyl and redo the test. if the numbers get better or back to normal, I think that means its a ring problem. might want to do some research on that to confirm.
valve lash test just means adjust your valves and redo the test.
Old Dec 30, 2006 | 04:23 AM
ITRnorway's Avatar
i have used the oil in cylinder test and can confirm it works
Old Dec 30, 2006 | 12:20 PM
rino924's Avatar
Community Builder
Default Re: (ITRnorway)
this is unreal, i CANNOT locate a leakdown tester anywhere around here. I've been on the phone all day to every place imaginable.
anyone know a rough estimate of how much it would cost if i run the car to Honda?
is there maybe another name for the actual tester itself?
Old Dec 30, 2006 | 01:08 PM
yankkesrule's Avatar
Leak down tester. Cylinder leakage tester
Old Dec 30, 2006 | 01:41 PM
rino924's Avatar
Community Builder
Default Re: (yankkesrule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yankkesrule &raquo;</TD></TR><TR><TD CLASS="quote">Leak down tester. Cylinder leakage tester</TD></TR></TABLE>
adictionbass
Sep 22, 2006 06:40 PM
Chris F
Nov 1, 2004 09:08 PM
oMek
Oct 27, 2003 12:04 PM
Black R
Aug 6, 2003 04:22 PM
Jesse H
Nov 4, 2001 08:59 PM
