92 accord tran problem
you can use the service connector to get the flash code link below
http://members.troublecodes.ne...n.jpg
Is the speedo working?
Check to see if the 'S' light stays on when you turn the key on, or you can reset the Computer and see if the problem goes away for a short while.
Check to see if the 'S' light stays on when you turn the key on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blas0827 »</TD></TR><TR><TD CLASS="quote">yes the s sign is on do you think its my trans computer</TD></TR></TABLE>
Well if you're to lazy to check the code; sure go ahead and replace anything you desire.
"Check to see if the 'S' light stays on when you turn the key on"
How tough can that be? You've said twice the 'S' light is on when driving, but that wasn't the question.
Sure I'm suspicious of the trans computer but it isn't PROVEN yet
hondadude thanx for your help i went to a junk yark found a trans computer the same part number i payed $70 for it i put it in and disconnected the battery for 10mins then i drove it its fixed its bid 1 hour no s light ill keep you posted
92AccordLXowner
Sep 11, 2009 07:33 PM
