92 accord tran problem
my car gets stuck in 2th gear and the s sign is lite
Re: 92 accord tran problem (blas0827)
you can use the service connector to get the flash code link below
http://members.troublecodes.ne...n.jpg Is the speedo working? Check to see if the 'S' light stays on when you turn the key on, or you can reset the Computer and see if the problem goes away for a short while. |
yes if i take a fuse out and let it sit drive good for 10min then it happens again
Re: (blas0827)
Check to see if the 'S' light stays on when you turn the key on.
you can use the service connector to get the flash code link below http://members.troublecodes.ne...n.jpg |
yes the s sign is on do you think its my trans computer
Re: (blas0827)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blas0827 »</TD></TR><TR><TD CLASS="quote">yes the s sign is on do you think its my trans computer</TD></TR></TABLE>
Well if you're to lazy to check the code; sure go ahead and replace anything you desire. "Check to see if the 'S' light stays on when you turn the key on" How tough can that be? You've said twice the 'S' light is on when driving, but that wasn't the question. Sure I'm suspicious of the trans computer but it isn't PROVEN yet |
hondadude thanx for your help i went to a junk yark found a trans computer the same part number i payed $70 for it i put it in and disconnected the battery for 10mins then i drove it its fixed its bid 1 hour no s light ill keep you posted
ive bin driving the car all day its good now thanx again
