STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD?
Old Dec 28, 2006 | 08:02 PM
turbosol_16's Avatar
Default STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD?
STOCK PR3 HEAD 500-600WHP? GOOD IDEA OR BAD?
IS IT GOING TO DROP A VALVE ?.....WITH A GOOD TUNE ...
WHAT ARE OTHER PEOPLES HP NUMBERS THAT HAVE A STOCK HEAD?....
Old Dec 28, 2006 | 08:14 PM
Boostfed's Avatar
New User
Default Re: STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD? (turbosol_16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosol_16 &raquo;</TD></TR><TR><TD CLASS="quote">STOCK PR3 HEAD 500-600WHP? GOOD IDEA OR BAD?
WHAT ARE OTHER PEOPLES HP NUMBERS THAT HAVE A STOCK HEAD?....</TD></TR></TABLE>
My old 84mm B16A set up with Stock B16A head BUT upgraded springs and retainers made 616whp 28psi. My current set up is a stock sleeved LS/VTEC with stock B16A head again with upgraded valvesprings and retainers has made 620whp 450 ft-lb torque though only ran at the track with about 540whp
Old Dec 28, 2006 | 09:50 PM
eg:R's Avatar
just upgrade your springs and retains. and you will be good
Old Dec 29, 2006 | 07:15 AM
BlakeJ53's Avatar
If you dont want to upgrade springs and retianers make sure you have the stock revlimiter in it. But vavle springs are cheap insurance..
Old Dec 29, 2006 | 08:39 AM
ninesecrx's Avatar
Default Re: STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD? (BlakeJ53)
Any time you are in a boosted application, springs and retainers are a must esp. at your hp level. If you have 25 pds of boost on your motor, you just took off 25 pds. of seat pressure off your valve. Even if a guy gets away with it once or twice, your just asking for issues to at least not run springs and retainers.
Old Dec 29, 2006 | 09:15 AM
quicksilver1689's Avatar
i ♥ snails
Yeah exatly the pressure in the combustion chamber is going to want to act on the valves and try to move them. Valve float can occur much easier even understock rev limit because of the boost.
Old Dec 29, 2006 | 09:30 AM
b18sihatch's Avatar
upgrade springs and retainers
Old Dec 29, 2006 | 09:32 AM
SOHC_MShue's Avatar
get the springs and retainers. I've seen bad **** happen before with the valves with high boost even at stock redline.
Old Dec 29, 2006 | 09:46 AM
Chip's Avatar
Default Re: STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD? (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">Any time you are in a boosted application, springs and retainers are a must esp. at your hp level. If you have 25 pds of boost on your motor, you just took off 25 pds. of seat pressure off your valve. Even if a guy gets away with it once or twice, your just asking for issues to at least not run springs and retainers. </TD></TR></TABLE>
Stock honda intake valve is what, 33mm? That's about 1.3 inches, and the surface area works out to be about the same in square inches. So at 25 pounds per square inch of boost you're looking at about 33 pounds off of the seat pressure, and at 30 psi you're looking at almost 40 pounds off the seat.
Old Dec 29, 2006 | 10:20 AM
Default Re: STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD? (Chip)
well if i do valve springs and retainers.... will the stock valves handle the heat and high hp????
Old Dec 29, 2006 | 10:30 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosol_16 &raquo;</TD></TR><TR><TD CLASS="quote">well if i do valve springs and retainers.... will the stock valves handle the heat and high hp????</TD></TR></TABLE>
Read my previous post in this thread as well as others.
Old Dec 30, 2006 | 08:41 AM
Default Re: STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD? (Boostfed.com)
ive heard of people dropping valves.... is it because of a crappy valve job on the head or poor tuning?
Old Dec 30, 2006 | 08:43 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosol_16 &raquo;</TD></TR><TR><TD CLASS="quote">ive heard of people dropping valves.... is it because of a crappy valve job on the head or poor tuning?</TD></TR></TABLE>
most likely used and abused equipment.
Old Dec 30, 2006 | 09:06 AM
bigislandc2's Avatar
a buddy of mine had a built bottom and stock b16 head ans made 550whp on his integra turbo top mount.
Old Dec 30, 2006 | 09:14 AM
Boostfed's Avatar
New User
Default Re: STOCK PR3 HEAD 500+ WHP GOOD IDEA OR BAD? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
most likely used and abused equipment. </TD></TR></TABLE>
Or just over revved, valve doesn't cause a dropped valve usually is due to valvesprings or over revving where the valve taps the piston and knocks teh keepers out , at least from what I know. Others can probably elaborate more on the subject like the almighty Tony1
Old Dec 30, 2006 | 11:32 AM
RedEj8's Avatar
Depending on how many miles are on this head.It might be a good idea to get new valves along with your springs and retainers.
Bseriescivic5
Sep 2, 2009 06:13 AM
dunkd
Feb 27, 2005 09:12 AM
Trak_Day
Sep 11, 2003 12:32 PM
spoon23_JDizM AkA SpOoN20
Mar 20, 2003 06:17 PM
