IACV: hiss at idle?
F22B2. I hear a very faint hiss under the hood when my car is idling (warm). With a stethoscope, I can tell that it's definitely something near the back of the throttle body, maybe the IACV. Something in that area is definitely hissing, and when I press on the throttle cable and the revs go up the hiss suddenly goes away . Is this a vacuum leak, or am I paranoid?
is the engine running right?
does it idle normal?
If the answer is yes;
you are Paranoid
All joking aside, if you suspect a vacum leak spray around the area with carb cleaner to see if the idle changes.
Modified by hondadude at 7:16 PM 12/28/2006
you are Paranoid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">
you are Paranoid</TD></TR></TABLE>
Figured. Thanks.
Figured. Thanks.
Takumi Fujiwara
Dec 25, 2005 10:26 AM
