starter spinning, not engaging flywheel
Old Dec 28, 2006 | 09:50 AM
G60's Avatar
G60
Default starter spinning, not engaging flywheel
Finally got the starter moving. Tried to get the car started up, at first it turned over a few times, refilling fuel lines etc since everything drained when I swapped the motors. It started to catch, then stalled out. Tried again, and now the starter doesn't seem to be engaging the flywheel, I just hear it spinning away. I'm ready to set this friggin car on fire...any ideas?
Old Dec 28, 2006 | 12:20 PM
e jay one's Avatar
Default Re: starter spinning, not engaging flywheel (G60)
your starter sylonoid is bad or sticking just get another starter this happened to me.
Old Dec 28, 2006 | 02:04 PM
G60's Avatar
G60
Default Re: starter spinning, not engaging flywheel (e jay one)
The solenoid is fine. When I turn the key, the starter is spinning. Even if the starter is not wired to the solenoid, when the key is turned you can hear the solenoid clicking over. I'm not sure if the starter motor itself has worn out, or if it just needs some lube or what. It was working fine before I did the motor swap.
Old Dec 28, 2006 | 02:14 PM
JT2MA71's Avatar
The gear isn't being pushed out. Get a new starter.
Happens all the time with ma70 supra starters...they'll spin fine, but won't push out to engage the flywheel/flex plate.
Old Dec 28, 2006 | 04:43 PM
e jay one's Avatar
Default Re: (JT2MA71)
well mine did the same exact thing it would work sometimes and sometimes just spin so get another one.
Old Dec 29, 2006 | 10:10 AM
colnago's Avatar
i agree, your starter motor is fine, but sounds like your solenoid is not causing your gear to come out. replace starter or find a used solenoid at the junkyard.
cheap fix.
colnago
Old Dec 29, 2006 | 11:31 AM
G60's Avatar
G60
Default Re: starter spinning, not engaging flywheel (colnago)
I thought the gear came out on the splines, through centribugal force? Not because the solenoid pushes it out.
Old Dec 30, 2006 | 06:25 PM
colnago's Avatar
true, the solenoid is like a relay that allows battery power to starter motor, it also allows the bendix gear to come out to engage flywheel.
it's a little more complicated than that, as there also is a overrunning clutch that could be slipping an not allowing gear to come out.
Old Dec 30, 2006 | 06:44 PM
Tippyman's Avatar
Just get a new starter, trust me. Don't ask how I know. Those soldenoids are easy to get fucked up.
I got one at a junkyard for like $8.It's easy, simple, and will most likely fix ur problem. And hell, if it doesn't, you know the problem lies elsewhere.
Old Oct 13, 2020 | 12:58 PM
John Will's Avatar
I'm having a similar problem but I got a new starter and it's the same
​​​The starter will spin and make a grinding noise but no start
dmanfree
Jun 21, 2013 12:38 PM
GoneImport
Feb 18, 2008 06:45 AM
h22a_black
Feb 13, 2008 06:12 AM
383chevy
Jan 25, 2007 07:58 PM
cstay
May 14, 2004 06:30 PM
