TL Hid problem
Old Dec 27, 2006 | 06:06 PM
dreams_of_ek9's Avatar
Default TL Hid problem
I got a set of Tl hids (legally), and im having problems getting them to work. I cut the the headlight wires and put clips on them and pluged them in to the box, turned on the lights but i got no light, anybody can help??????? Its a 94 eg
Old Dec 27, 2006 | 06:45 PM
Default Re: TL Hid problem (dreams_of_ek9)
tttt
Old Dec 27, 2006 | 06:52 PM
john666's Avatar
wires backwards ? or maybe in the wrong plug.. ie high beam not low beam
Old Dec 28, 2006 | 04:02 PM
Default Re: TL Hid problem (john666)
i tried both high beam and low beam wire, still got no light, is it possible its not getting enuff power??? am i missing anthing, i got the box, the wire that goes from the box to the bulb w/ the socket on it and the bulb.
Old Dec 28, 2006 | 07:59 PM
john666's Avatar
the read someplace that hids use less power then normal bulbs.. i would try something like plugging it directly to the car battery.. should light up..
Old Dec 29, 2006 | 09:20 AM
thanks i'll try it
Old Dec 29, 2006 | 09:29 AM
joker4096's Avatar
make a harness for the hids unless you want to burn up your engine wiring. I believe there should be a power and a ground for the hid. search for the harness in the archives
Old Dec 29, 2006 | 10:02 AM
Default Re: (joker4096)
ok i'll try looking for the harness
Old Dec 29, 2006 | 10:09 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreams_of_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">i tried both high beam and low beam wire, still got no light, is it possible its not getting enuff power??? am i missing anthing, i got the box, the wire that goes from the box to the bulb w/ the socket on it and the bulb. </TD></TR></TABLE>
Unless the ballast and the ignitor are combined, you're missing a vital piece of the equation there, champ. There should be two boxes and a bulb for each side.
Old Dec 29, 2006 | 04:20 PM
Default Re: TL Hid problem (Archidictus)
thanks everybody, got a friend to do it for 50 bucks
jdm89crxhf
Lighting
Apr 21, 2012 01:20 PM
88 EF Hatch
Lighting
Nov 4, 2008 03:55 PM
b16a3delsol
Lighting
14
Jan 29, 2008 07:27 AM
b16hybridsol
Sep 25, 2004 01:45 AM
GhettoBrawls
Jun 28, 2003 09:09 AM
