Good cams for running Turbo
Anybody know of any good companys that make a good turbo cam, I was planning on running crower, but I'm still not sure yet. I've heard that the integra tpyr cams work well also if your not boosting past say 11psi, but I don't know.
Thanks
Lee
Thanks
Lee
for the street, lower PSI, use the stock cams... if you move up past 10ish PSI, GSR cams work great.
ITR cams if you want all out HP...
CTR intake cam is a no go, cause all it is is a ITR intake cam with more overlap which is bad for turbo.
So the exhaust cam for the type r is the same, damn i know an *** of people if they new that tey would gave saved so much money, but are the itr cams good for say 11-15 psi.
Lee
Lee
