obd-0 b16a into 93 del sol
I just bought an obd-o b16a and an unsure of the what to do to convert the engine to obd-1 and what harness and things i would need to use. any helps appreciated.
if your delsol had a vtec motor in it you can use that harness..just extend the o2 sensor, and omit the knock sensor (if using the jdm ecu)...you will need b series mounts, axles, linkage, and b16 obd1 distributor...also if you want to keep ac and ps you will need new brackets for them...
Mohsin
16
Dec 28, 2007 09:04 AM
markiebredsol
16
Jul 27, 2003 12:21 AM
