NEED HELP WITH MY CAR SHAKING???
i drive a 99-00 civic ex ..... and my problem is when i drive it ... it drives fine until i reach 60 mph and my whole rear end shakes really bad !!!! i thought it was because of unbalanced tires but i went to get new tires and balanced but it still shakes really bad at high speeds ....
what could i be looking at as a problem ???? PLEASE HELP NEED TO FIX ASAP
THANKS HONDA-tech
THANKS HONDA-tech
sounds like you have a broken motor mount. you're going to have to take some time and look which one is broken then go ahead and replace it.
could also be your wheel bearings, tie rods, rack and pinion, could be a number of thing, check all major suspension parts and let is know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">sounds like you have a broken motor mount. you're going to have to take some time and look which one is broken then go ahead and replace it.</TD></TR></TABLE> if it were a motor mount wouldnt it make the front SHAKE CRAZY INSTEAD OF THE REAR??? hrmmm ...,would the wheel bearings cause it from shaking reallly bad???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsuperxsonx »</TD></TR><TR><TD CLASS="quote"> if it were a motor mount wouldnt it make the front SHAKE CRAZY INSTEAD OF THE REAR??? hrmmm ...,would the wheel bearings cause it from shaking reallly bad???</TD></TR></TABLE>
hmmm...missed the whole shaking of the rear. it can also be a faulty tire. happened to me once, where my rear tire had a bubble.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cjek4 »</TD></TR><TR><TD CLASS="quote">check if your axel bolt is tight it should be a 32mm</TD></TR></TABLE>
no axle in the back of the car....have you been grabbing up the e-brake..you might have a flat spot on the tire...but def check to make sure the wheel is on centered because they are hub-centric
You probably have a tire with tread seperation. Jack the car up in the rear, drop the e-brake and spin the the tires by hand as fast as you can. If it looks like there's a lump in the tire you have tread seperation. If that is the case you will need a new tire.
touge_dorifuto
15
Jul 22, 2005 09:53 AM
95civic LS
Mar 30, 2005 03:24 PM
