I'm officially pissed off/stumped. v.tranny problems
Old Dec 27, 2006 | 08:27 AM
Beckington's Avatar
Default I'm officially pissed off/stumped. v.tranny problems
Here is a quick run down...
Boosted/Built D16A6 w/ D15 tranny
- Tranny Grinds 9/10 times when going into reverse.
- Drained and re-filled tranny w/ Syncromesh about 15 minutes ago.
- When its cold, I can't get it into gear without a large amount of violent force (except reverse...but then it grinds)
- When driving its considerably more difficult to shift
- When stopped its very tough to get it into first gear.
- When I drive hard and romp on it, for the next 30 seconds to 1 minute it "seems" as though its easier to shift.
- My shift linkage and stabilizer is fine
- Shifter stabilizer bushings were replaced a couple months ago
- It only started doing it, recently and all of a sudden...every since it got cold out.
- My clutch slips with anything above 18 psi but i'm currently at 11 and it holds fine.
- I bled my slave cylinder. Clutch pressure is good.
- No grinding in any other gears, but reverse. No clunking noises, or anything unusual.
Do we have any other suggestions to as what it may be?
I don't think it is a spring in the clutch, just for the reason that the difficulty of shifting is variable. It seems as if I get the tranny warmed it, it seems to get better. But once I'm at a light and it cools down...its hard.
So WTF IS IT?!!!!
Old Dec 27, 2006 | 08:44 AM
platinumx6's Avatar
im thinkin arby's
Old Dec 27, 2006 | 08:48 AM
Beckington's Avatar
Default Re: (platinumx6)
hey dumb ****...
i answered your question respectfully and thoroughly (even though a blind guy with boxing gloves could do it).
do the same for me.
don't reply with shitty responses.
kthnx.
Old Dec 27, 2006 | 08:56 AM
platinumx6's Avatar
Hey guy, i dont know the answer to your question thats why i came and bumped it, sorry for not saying "thanks and bump" and made it more intresting. I even searched for ya, but came up empty. Just keeping your **** on top.
thanks btw
Old Dec 27, 2006 | 09:07 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
this thread my get a answer your looking for in the TECH forum faster...i've seen your problem be a few things .... post it there one of the tranny guru's will help you
Old Dec 27, 2006 | 04:51 PM
Beckington's Avatar
Default Re: (Throwdown)
i just pulled back my slave cylinder boot and it seems to have a little liquid in it.
I'm willing to bet, the slave cylinder is fucked, therefore not disengaging the clutch fully....causing shifting to suck *****.
Another thing is...
If I have the car in gear at a light, with the clutch depressed to the floor....the car creeps foward slightly.... if i pop it into nuetral...the car stops. If i jamb it back into gear...it starts to creep foward again...(even with the clutch pedal depressed)
Old Dec 27, 2006 | 04:59 PM
9200RPM's Avatar
Default Re: I'm officially pissed off/stumped. v.tranny problems (Beckington)
your last guess sounds right...
Demonis
Honda Civic (2006 - 2015)
Mar 24, 2007 09:37 AM
Beckington
Dec 28, 2006 08:24 PM
Ge-money
18
Nov 18, 2006 05:43 PM
Edwardo911
Aug 31, 2004 01:25 PM
Skinnypunk
May 30, 2004 10:41 AM
