Bad CV joint???
Old Dec 27, 2006 | 07:01 AM
AnotherEJ's Avatar
Default Bad CV joint???
Ok so I jacked my car up just now to change my oil and I noticed my passenger side CV boot is torn(it looks like it ripped clean all the way around and is not connected at all). There is grease all over my rim on the inside as you would imagine. I don't notice any shaking when driving. I don't hear any clicking either... could the boot just need replacing? or do I need a new axle?
Any help is appreciated.
Old Dec 27, 2006 | 07:53 AM
_Keith_'s Avatar
id just get a new axles.
Old Dec 27, 2006 | 07:58 AM
AnotherEJ's Avatar
Default Re: (_Keith_)
Well im broke right now because I just ordered my suspension and I wondered If i could get away with just the boot for now since it drives fine.
How long would I be ok driving with the boot torn also?
Old Dec 27, 2006 | 09:55 AM
mikeunreal2's Avatar
Default Re: (AnotherEJ)
you can run with broken axel for awhile. your axel isnt going to fall apart or anything. if your tight on money and dont see any direct signs its bad, replace the boot and fix it when you get the money. you will defnitally know when an axel is bad or goes bad
mike
Old Dec 27, 2006 | 10:04 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnotherEJ &raquo;</TD></TR><TR><TD CLASS="quote">Well im broke right now because I just ordered my suspension and I wondered If i could get away with just the boot for now since it drives fine.
How long would I be ok driving with the boot torn also?</TD></TR></TABLE>
ride it out until the cv joint goes out. when that happens then replace it.
Old Dec 27, 2006 | 10:08 AM
AnotherEJ's Avatar
Default Re: (mikeunreal2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 &raquo;</TD></TR><TR><TD CLASS="quote">you can run with broken axel for awhile. your axel isnt going to fall apart or anything. if your tight on money and dont see any direct signs its bad, replace the boot and fix it when you get the money. you will defnitally know when an axel is bad or goes bad
mike</TD></TR></TABLE>
Your wack! lol I just wonder how long it will take to go out since there is a bunch of rocks and stuff already getting in there
Old Dec 27, 2006 | 10:10 AM
philosofy1's Avatar
Your wack! lol I just wonder how long it will take to go out since there is a bunch of rocks and stuff already getting in there</TD></TR></TABLE>
there is no telling how long it will take. how much driving and weather conditions play a major factor on how long it will take.
i have had some go out right away, then there has been times where it has taken about 6 months to go out. it all depends.
Old Dec 27, 2006 | 10:13 AM
just get a new boot and fix it temp is you aint got no bills yo!
AnotherEJ's Avatar
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
i have had some go out right away, then there has been times where it has taken about 6 months to go out. it all depends.</TD></TR></TABLE>
Yeah Im just wondering If I should go ahead and get it done while im off from work for a little bit or go ahead and do it now.
pip-A guy in the northeast said he would do it for me at his shop for 40 bucks, and it would only take 30 minutes
Old Dec 27, 2006 | 10:31 AM
then just do it and call it a day!
mike
Old Dec 27, 2006 | 10:32 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 &raquo;</TD></TR><TR><TD CLASS="quote">then just do it and call it a day!
Old Dec 27, 2006 | 11:12 AM
gabebauman's Avatar
Re-Manufactured axle from AutoZone.
GSR936
Feb 26, 2009 02:59 PM
ri3
Honda Civic (2006 - 2015)
Feb 13, 2009 11:46 PM
k_lude
Dec 28, 2006 07:41 PM
mikeunreal
Nov 22, 2005 08:42 PM
mist sITR
Sep 25, 2003 11:02 PM
