what is the best oem cam for turbo b16?
Old Dec 26, 2006 | 12:36 PM
ivt-t's Avatar
Default what is the best oem cam for turbo b16?
i just try find the cheapest way to make more power with less money.
Old Dec 26, 2006 | 12:47 PM
b18sihatch's Avatar
Default Re: what is the best oem cam for turbo b16? (ivt-t)
GSR
Old Dec 26, 2006 | 01:25 PM
Mugencrxsir1's Avatar
Default Re: what is the best oem cam for turbo b16? (b18sihatch)
GSR
Or just a blox turbo cam off ebay, sometimes you can find them for $200ish!
Old Dec 26, 2006 | 02:15 PM
2redstars's Avatar
what about the itr/ctr combo?
Old Dec 26, 2006 | 02:40 PM
EGunit's Avatar
gsrs are generally pretty cheap to buy secondhand.....best oem cam overall goes to the ITR/CTR units. they make good, good power.
Old Dec 26, 2006 | 04:38 PM
Redline130's Avatar
Default Re: what is the best oem cam for turbo b16? (EGunit)
Best OEM is probably the ITR/CTR cams.
Old Dec 26, 2006 | 04:58 PM
Synapse Motorsport's Avatar
Default Re: what is the best oem cam for turbo b16? (Redline130)
ITR/CTR
Old Dec 26, 2006 | 10:31 PM
ivt-t's Avatar
do you think that B18C4 cams are the same as gsr?
Old Dec 28, 2006 | 09:49 PM
JALOP B16's Avatar
Gsr. The ctr/itr will need a late vtec point setting for turbo.
Old Dec 28, 2006 | 10:59 PM
zexxbo's Avatar
Default Re: what is the best oem cam for turbo b16? (JALOP B16)
turbo= teh GSR cams
all mota= itr/ctr cams
Old Dec 29, 2006 | 06:32 PM
jetnbyu93's Avatar
Default Re: what is the best oem cam for turbo b16? (zeimbo)
ITR/CTR
Old Dec 29, 2006 | 06:54 PM
Semnos's Avatar
Default Re: what is the best oem cam for turbo b16? (jetnbyu93)
ITR/CTR
Old Dec 29, 2006 | 07:52 PM
ExVtec's Avatar
BEST OEM cam is ITR/CTR
Best bang for your buck OEM cam is GSR.
Old Dec 29, 2006 | 07:58 PM
project dc2's Avatar
Default Re: what is the best oem cam for turbo b16? (ExVtec)
<FONT SIZE="6">BEST OEM CAM--- ITR </FONT>
HOWEVER. if you're setup is built, you'd find real good gains with larger all motor cams such as BLox B's .
Old Dec 29, 2006 | 08:17 PM
Tchleung's Avatar
01 ITR cams, or CTR cams
Old Dec 29, 2006 | 11:40 PM
ivt-t's Avatar
the queston again
is the gsr same as the b18c4 cam?
Old Dec 30, 2006 | 10:11 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">turbo= teh GSR cams
all mota= itr/ctr cams</TD></TR></TABLE>
LMFAO!
Old Dec 30, 2006 | 02:12 PM
Chip's Avatar
it's been proven that ITR/CTR cams make more power than GSR's on a turbo setup, so get your **** outta this post
Old Dec 30, 2006 | 02:39 PM
Ruben19's Avatar
Default Re: what is the best oem cam for turbo b16? (project dc2)
HOWEVER. if you're setup is built, you'd find real good gains with larger all motor cams such as BLox B's .[/QUOTE]
so you are saying that i can use blox b cams for a turbo set up with no problems.
im a all motor guy right now but im going turbo soon.
i
Old Dec 30, 2006 | 02:46 PM
nowtype's Avatar
Default Re: what is the best oem cam for turbo b16? (Ruben19)
Your choice of cam should be based on your turbo setup. A turbo setup with a very small turbine/housing and small volume exhaust manifold in theory should like GSR cams far more than ITR cams. A larger turbine/housing and a long runner manifold should prefer ITR cams or even more aggressive mild all motor cams. There have been posts about this where I explain why and how this worked in a very basic way. Do some searching if you want.
Old Dec 30, 2006 | 02:51 PM
zexxbo's Avatar
Default Re: what is the best oem cam for turbo b16? (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">it's been proven that ITR/CTR cams make more power than GSR's on a turbo setup, so get your **** outta this post </TD></TR></TABLE>
yea, and for the price that youd pay for itr or ctr cams, you could get a nice set of turbo aftermarket cams and since..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivt-t &raquo;</TD></TR><TR><TD CLASS="quote">i just try find the cheapest way to make more power with less money.</TD></TR></TABLE>
the gsr cams are the better route for what hes trying to do. kthxbye
Old Jan 2, 2007 | 12:30 PM
ivt-t's Avatar
thanks boys!
Old Jan 2, 2007 | 04:06 PM
crucian's Avatar
Go with whatever oem cam has the highest lift. And please don't go with GSRs over a cam that has higher lift than it. Just doesn't make sense.
Old Jan 3, 2007 | 09:37 PM
katoeh2o's Avatar
Are GSR really much better than the b16 cams. I would think if you are gonna go through the truoble of changing them you sould get the ITR or CTR.
Old Jan 3, 2007 | 09:45 PM
crucian's Avatar
Default Re: (katoeh2o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o &raquo;</TD></TR><TR><TD CLASS="quote">Are GSR really much better than the b16 cams. </TD></TR></TABLE> Nope!
