more b16 question?
Old Dec 26, 2006 | 09:44 AM
crxpwr1's Avatar
Default more b16 question?
hey I was going to start taking off my dashpots and I cam across this?
It is connected to where the throttle cable goes
and also one quick question is this the knock sensor and if not where is it
Old Dec 26, 2006 | 09:46 AM
user 72830283's Avatar
that second pic looks like the IAT sensor...the knock sensor is on the block under your intake manifold on the BACK of your motor...its easier to see from underneath..
Old Dec 26, 2006 | 10:37 AM
Loserkidwac's Avatar
Default Re: (pr3d)
I still haven't got a straigh answer to what pick one is, but i haven't researched to hard yet but I believe it may be for A/C, it would rais the throttle when you engage the A/C compressor...but i have also heard it is used for cold idle...
the second pic is the IAT...the knock sensor is found right around the oil filter on the back for the block, similar location to the OBD0 fan switch sensor
Old Dec 26, 2006 | 10:44 AM
B6tizzleHatch's Avatar
Default Re: (Loserkidwac)
pic one is part of cruise control, that was on mine and i pulled it off
Old Dec 26, 2006 | 10:47 AM
zccr-xsi's Avatar
yea some crxs xame with c/c as an extra option.
Old Dec 26, 2006 | 10:53 AM
Default Re: (zccr-xsi)
I'm still curious about pic1...correct me if I'm wrong but there is only 1 vac port coming off of it that goes to the intake, pre-throttle body...there is a check valve for it in the vac line but there is no other connections, other than the one to the throttle lever? just curious how it works...
my old a6 also had the same type of device on it, yet no USDM CRXs had C/C...thats why i concluded either A/C or cold idle....
Old Dec 26, 2006 | 01:02 PM
crxpwr1's Avatar
yea Im thinking it might be cruise control...so do I take off the whole bracket connect to where the spring sits for the throttle cable?
Old Dec 26, 2006 | 04:18 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">I'm still curious about pic1...correct me if I'm wrong but there is only 1 vac port coming off of it that goes to the intake, pre-throttle body...there is a check valve for it in the vac line but there is no other connections, other than the one to the throttle lever? just curious how it works...
my old a6 also had the same type of device on it, yet no USDM CRXs had C/C...thats why i concluded either A/C or cold idle....</TD></TR></TABLE>
one side of pic 1 goes to the intake tube , the difference in vacuum when the throttle is closed keeps the throttle plate in the tb from slamming shut. it just closes slower. I don't think this system did much good or worked all that well because it was deleted on obd1+ motors . it is safe to say ditch it
it has nothing to do with ac or cruise control
Old Dec 26, 2006 | 08:10 PM
yea..you canjunk it..i removed it to ccommodate my 3-point strut bar...
Bic1090
11
Feb 1, 2012 05:45 PM
TrojanMan01
Honda S2000
Mar 5, 2010 11:19 AM
Derek88
Jun 17, 2007 03:47 PM
FullJDMEg
Oct 30, 2005 09:12 PM
JDMCivicHatch93
May 21, 2003 08:04 PM
