t3/t4 maxium effency
Old Dec 25, 2006 | 06:35 PM
tyrone27's Avatar
Default t3/t4 maxium effency
t3/t4 turbo stage 3 .63. here are the specs on it:
Turbine Housing A/R .63 T3 NB032
Compressor Housing .50 TO4E
Turbine Wheel T300 56 mm (Ind. 2.20" May.2.42")
Compressor Wheel ST2 T4 58.15mm (Ind. 2.29" May.3.30")
What will this turbo max out at in HP?
Old Dec 25, 2006 | 10:08 PM
b18sihatch's Avatar
Default Re: t3/t4 maxium effency (tyrone27)
what are the specs of your motor.
what is it rellivant to how much a turbo can max out at, if you have a turbo that maxs out at 1000whp and your motor is only sufficent to handle 300, obviously the raio from motor handling to turbo handling is going to be greater than you need.
so knowing your goals and knowing your motor will best know if that turbo will suffice you or not
Old Dec 25, 2006 | 10:14 PM
Dunc's Avatar
BCICAN
Default Re: t3/t4 maxium effency (b18sihatch)
Well if I knew for sure I would answer your question instead of making it more complicated **cough above cough** I dunno, my guess is in the 400's
Old Dec 25, 2006 | 10:18 PM
b18sihatch's Avatar
Default Re: t3/t4 maxium effency (AF-P Dunc)
more complicated i think not! my point proven well, if he is asking to find out what his limits are then i say well good for you.
but if he is asking to find out whats the max he can push with it and his motor setup has a max limit that is smaller than your guess of 400whp than he should be asking what is a efficent ammount of psi should i be looking at to make this turbo work with my motor.
normally and i speak vauge, turbos have less of a limit than motors do. and that depends on the motor at hand and the turbo!
Old Dec 25, 2006 | 10:25 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">more complicated i think not! my point proven well, if he is asking to find out what his limits are then i say well good for you.
normally and i speak vauge, turbos have less of a limit than motors do. and that depends on the motor at hand and the turbo!</TD></TR></TABLE>
mmmmm well the point is still mute due to this: https://honda-tech.com/zerothread?id=1478127. That turbo is not going to outperform any of those numbers in that thread haha. Plus he could have a complete race car ready to roll, and has to get his simple question answered
Old Dec 25, 2006 | 10:29 PM
b18sihatch's Avatar
your point proves well, however if that isnt the case than a little bit of imformation is going to be required. if he is looking to find out if that turbo is sufficent for his setup, we need to know the setup at hand.
only reason i say so is that you never know with people now days
Old Dec 25, 2006 | 10:32 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">your point proves well, however if that isnt the case than a little bit of imformation is going to be required. if he is looking to find out if that turbo is sufficent for his setup, we need to know the setup at hand.
only reason i say so is that you never know with people now days</TD></TR></TABLE>
If it isn't the case? haha that link proves power is able to be had from stock to built setups. Nevertheless you can win, merry christmas.
EDIT: Sorry, had to correct my spelling errors
Modified by AF-P Dunc at 3:41 AM 12/26/2006
Old Dec 25, 2006 | 10:34 PM
b18sihatch's Avatar
im not in it to win, its christmas we all win
Old Dec 25, 2006 | 11:38 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-P Dunc &raquo;</TD></TR><TR><TD CLASS="quote">I dunno, my guess is in the 400's</TD></TR></TABLE>
x2
I would guess, low to mid 400's.
ragethemachine86
Oct 15, 2006 12:29 PM
shawn_crx
Jan 7, 2005 02:27 PM
booscivic
Dec 15, 2003 07:14 PM
DigitalFusion
Jun 7, 2002 01:17 PM
InfamousRS
Dec 16, 2001 01:47 AM
