1990 Accord How u check the check engine light?
Old Dec 25, 2006 | 12:10 PM
vtec25's Avatar
Default 1990 Accord How u check the check engine light?
Need to know cuz it got the CEL and its overheating and changed the the thermostat and also runs real ruff and takes a few cranks to start.
Old Dec 25, 2006 | 12:43 PM
hondadude's Avatar
Default Re: 1990 Accord How u check the check engine light? (vtec25)
at the top of the passenger side kick panel look for a BLUE 2 pin connector, if it has never been used it will be taped to the harness with BLUE tape
Modified by hondadude at 7:32 PM 12/25/2006
Old Dec 25, 2006 | 02:43 PM
standbackimapro's Avatar
Jumping the service connector as shown is the same way to do it when adjusting the timing right>?
Old Dec 25, 2006 | 02:54 PM
vtec25's Avatar
Default Re: (standbackimapro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">Jumping the service connector as shown is the same way to do it when adjusting the timing right&gt;?</TD></TR></TABLE>
Yes
I knew this for 92+(obd1) Honda's but i thought it would be diffrent on a 1990(obd0)
Old Dec 26, 2006 | 08:40 AM
Chaos3252006's Avatar
90-91 cb7 are obd1, mine is. I got a ecu with a light window so I count the blinks there. I only found it in a 90 se, so I grabbed it and installed it into my 91 lx.
Old Dec 26, 2006 | 05:21 PM
vtec25's Avatar
if u count the blinks on the ECU does'nt that make it obd 0???
Old Dec 27, 2006 | 06:43 AM
mozzandherb's Avatar
Honda-Tech Titanium Member
No it's OBD 1
Old Dec 27, 2006 | 07:36 AM
shmack2004's Avatar
Default Re: (mozzandherb)
short the connect like in the pic in the above post and count the blinks of the check engine light
it blinks in a code
for example
codes 1 to 10 will blink 1 to 10 times
codes over 11 will blink long and short blinks
so a code 42 will have 4 long blinks followed by 2 short blinks.
hope that helps
Chavy340
Oct 14, 2011 05:17 PM
tjd92accord
Jun 22, 2005 04:21 PM
Carson89X
Feb 10, 2005 08:17 AM
hatchinprogress
16
Jan 7, 2005 09:09 AM
Monty
Oct 18, 2002 04:01 PM
