distributor does not spin freely??
Old Dec 25, 2006 | 08:03 AM
97grnrs's Avatar
Default distributor does not spin freely??
i bought a crx si dist from someone on the forum and when i got it i went to rotate it to line it up with the cam groove and i noticed its real hard to turn.. it almost locks up at one point.. what is wrong with it? the rotor looks fine and all
Old Dec 25, 2006 | 08:21 AM
rayzian's Avatar
Default Re: distributor does not spin freely?? (97grnrs)
pretty much means it's no good, my old distributor was just like that and the tach would jump all over the place and stutter over 3k rpm and at times randomly shut off..
Old Dec 25, 2006 | 08:30 AM
Crx Jimmy's Avatar
the bearing is shot, you can try putting some oil in the bearing it might get you by for awhile and make it easier to turn
Old Dec 25, 2006 | 08:39 AM
colnago's Avatar
The bearing inside the distributor is partly seized. Can be replaced with a new one. they are like 12.00 dollars from a bearing store. Just take the old one out and bring with you, there are numbers stamped on the bearing that signal it's size. very common bearing, though. The trouble is getting it out. there are tamper resistant torx screws that need to come out. Then the sensor wheels need to be pressed of. Not hard just time consuming to do when it is your first one.
try to return it to seller if you can if you don't want to try to fix it. If you want to send to me i will replace bearing for 20.00 plus price of part.
good luck, colnago
an2ny888
Oct 19, 2022 06:57 PM
ijjz
Nov 28, 2006 04:47 AM
Phat Corolla
Nov 29, 2004 03:05 PM
See Are X
Dec 22, 2002 01:16 PM
Phat Corolla
Jan 29, 2002 06:48 AM
