d series cranks???
Old Dec 24, 2006 | 06:53 PM
iheartmyej8's Avatar
Default d series cranks???
are y8 and z6 cranks the same? the reason im asking, is i got a free z6 bottom end and i bought a y8 long block. and the y8 was knockin. so im afraid that the crank might be screwd up. so i was goin to use the z6 crank. im building the y8 to go turbo and put it in my ej8. thanks for any info
Old Dec 24, 2006 | 07:55 PM
bmw626's Avatar
Default Re: d series cranks??? (iheartmyej8)
i am using a y8 crank in my boosted z6, 10 pounds, 250whp, no problems... so my guess is that they are the same.
Old Dec 24, 2006 | 08:34 PM
canis's Avatar
yes there the same from what ive built up, but dont qoute me on that, look up honda them selves and theyll say the difference, if there is, its in the mean bearings...
Old Dec 25, 2006 | 04:30 PM
Default Re: d series cranks??? (canis)
so they are the same but i might have to use the z6 bearings?
Old Dec 25, 2006 | 06:23 PM
le0ftw's Avatar
KOBE IS GOD
I have used a y8 in a z6 and no problems at all.
Old Dec 31, 2006 | 09:47 PM
Default Re: d series cranks??? (KB24)
k thats koo. thanks for the replies. ill try and look it up sometime.
Syndacate's Avatar
For most part the whole engine is the same.
Yeah the cranks will work. Whether they're the same or not I'm not sure.
Old Jan 4, 2007 | 05:16 PM
Default Re: (Syndacate)
so everything will werk right? i might just use the z6 block. what would i have to do bout changing the z6 block to obd2?
Old Jan 4, 2007 | 07:31 PM
SinglecamMitch's Avatar
the only difference between the z6 and the y8 is the 6 dosent have the tapped hole for the knock sensor otherwise i think just swap your plugs over it think? if they are even different??
Old Jan 5, 2007 | 04:46 PM
Default Re: (SinglecamMitch)
sweet. so here comes a lil turbo d build.
Old Jan 5, 2007 | 05:12 PM
ABK's Avatar
ABK
Default Re: (iheartmyej8)
I think z6 crank has more oiling holes. I suggest using z6 bottom end because they are far more reliable. Y8s have issues with spining bearings.
Old Jan 7, 2007 | 04:08 PM
Default Re: (ABK)
well i dunno if its gona happen now. my buddy got rid of the z6 block. so i might just build the y8. and hope the crank aint bad. that or i might just wait and go w just a b16. i dunno.
Old Jan 7, 2007 | 07:53 PM
ABK's Avatar
ABK
Just find another d series. I used to get complete swaps for like $200-250. Go to your local shops they prolly have some sitting around that are far better to build then the one you got that was knocking.
TheCivicMafia
Feb 28, 2011 06:15 AM
TylerB
Mar 28, 2009 05:52 AM
b20accord
Aug 18, 2007 06:44 PM
Manny86
May 9, 2007 09:27 AM
EJ8-y8
Apr 9, 2006 03:50 PM
