Tial 44mm Wastegate is leaking
Old Dec 23, 2006 | 01:02 PM
wantboost's Avatar
Who is Mr Robot?
Default Tial 44mm Wastegate is leaking
I was checking the pressure at which my wastegate opens and its leaking... i apply compressed air to the lower nipple and it sounds like its leaking between shaft and the seal that goes through the lower housing.
i know its not the diaphram as i've checked that its not torn or seated. but its leaking around the actual shaft...
ideas?
Old Dec 23, 2006 | 03:59 PM
BoostedEG6's Avatar
Default Re: Tial 44mm Wastegate is leaking (wantboost)
operator error biznatch
Old Dec 23, 2006 | 04:42 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Tial 44mm Wastegate is leaking (BoostedEG6)
no not really
im worried to run it as i dont know what will happen
Old Dec 25, 2006 | 09:12 AM
ironcheftony's Avatar
over booooost prolly
my fake tial cracked and was leaking
the seal around the diaphram, metal area cracked off and leaked, and 2 screw's that hold my piston in came out and i kept over boosting, dint know why till i took it off and shook it
Old Dec 25, 2006 | 08:26 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (ironcheftony)
this is a real tial 44mm that i have never used... and its impossible to overboost a wastegate
Old Dec 26, 2006 | 09:43 AM
https://honda-tech.com/zerothread?id=1846279
Old Dec 26, 2006 | 09:51 AM
wantboost's Avatar
Who is Mr Robot?
yea mine is fine at the seal.
its around the bushing that presses into the lower half of the housing that the shaft passes through
Old Dec 27, 2006 | 12:52 PM
BoostedEG6's Avatar
Default Re: (wantboost)
quite being a biotch and just run it..... its fine, I think its more in your head than anything
Old Dec 27, 2006 | 10:23 PM
Synapse's Avatar
That's pretty typical. They're designed that way. As long as the valve is lifting under compressed air, you shouldn't have any problems. The funny part is that you will also get leakage past the diaphragm from the factory. Put your finger on the top nipple while compressed air is on the bottom port for a while and you'll see.
Old Dec 27, 2006 | 11:45 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Synapse)
eh, thats gay if you ask me...
synapse. is your wg done yet?
Old Dec 28, 2006 | 08:56 AM
Synapse's Avatar
It is hard to seal that valve stem, I've tried it with a Teflon seal (which just melted away), high temp o-ring (got baked). Then as a designer if you make the tolerances to tight, then you get galling, or binding. Or in the case of one of the most popular WGs out there, the metals grow and bind at peak temps.
Synchronic WG is in production now and will be available in mid to late January. If you wanted to use it as a traditional WG there are two chambers that can be used to lift up the valve. One of them is a pneumatically sealed chamber.
You can see what I mean in this vid (warning: long):
Click here to see Video
Old Dec 28, 2006 | 09:21 PM
drumking15's Avatar
nice vid
Old Dec 28, 2006 | 09:48 PM
*Boostwerks*'s Avatar
That is awsome! So of course I have to ask...how much are those going to run? The 50mm seems like a great gate especially if the flange is the same size as the 44. Have you done any real world testing of the valves?
Old Dec 29, 2006 | 12:47 PM
Synapse's Avatar
Default Re: (Boostwerks.com)
Of course there's been lots of testing and testing as we speak. Which is what is one of the factors that is causing it to take so long to get it available for retail.
You should see a tech article/test in Turbo Magazine in the next couple of months.
Old Jan 4, 2007 | 09:00 PM
jz98ctr's Avatar
nice work
yea....normal diaphragm WGs work but there is always room for improvement
can't wait for the release
Old Jan 5, 2007 | 06:43 AM
White Smoke's Avatar
i my honda
Global Mod
They always leak like that. Its normal! Does the WG actually not function or have you tried it?
Old Jan 5, 2007 | 12:07 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Tial 44mm Wastegate is leaking (White Smoke)
it has a little bit of valve lift. i know the tials dont have insane amounts but i havent been able to us it yet. waiting on a manifold for my sr20
Old Jan 5, 2007 | 12:30 PM
JamesS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synapse &raquo;</TD></TR><TR><TD CLASS="quote">
Click here to see Video</TD></TR></TABLE>
At the end of the video, you said "birth control". I think you meant to say "boost control". Otherwise, very informative video. Thanks!
Old Jan 5, 2007 | 01:21 PM
Synapse's Avatar
Default Re: (JamesS)
I did mean birth control. Remember diaphragms used in birth control? I don't trust them and don't believe diaphragms should be in Wastegates.
Old Jan 5, 2007 | 03:29 PM
jz98ctr's Avatar
rofl....diaphragms are the reason half of us are here lololol
Old Jan 5, 2007 | 04:16 PM
MrParks's Avatar
very nice, i think it will do very well.
hbyrd8701
Feb 1, 2007 05:50 PM
dpreludesi
Feb 9, 2003 06:34 PM
