Switch to Hasport, and still having kickbacks
Old Dec 22, 2006 | 09:30 PM
Del Sol on Steroids's Avatar
Default Switch to Hasport, and still having kickbacks
I installed a full set of Hasports regular 60 bushing, and I'm still having some kickbacks, could my side mounts be really that messed up?
Old Dec 22, 2006 | 09:34 PM
Luserkid's Avatar
Default Re: Switch to Hasport, and still having kickbacks (Del Sol on Steroids)
What do you mean by kick backs?
Old Dec 22, 2006 | 09:38 PM
more than average movement of the motor
Old Dec 22, 2006 | 10:31 PM
Luserkid's Avatar
Can you move the motor by hand back and forth or what? Which Hasports did you replace, all 3?
Old Dec 23, 2006 | 07:50 AM
MasterKwan's Avatar
Default Re: Switch to Hasport, and still having kickbacks (Luserkid)
I have Hasports all the way around and removed the front mounts to save weight. Motor doesn't move a lick. This is with a B18C5 in an EK/EJ hatch.
Old Dec 23, 2006 | 10:00 AM
full set, all three b18c into a del sol. And know I cant move it by hand
Old Dec 23, 2006 | 10:13 AM
Luserkid's Avatar
How do you know your motor is "kickbacking"? Your goign to have alot of vibration off of the solid mounts. Is that what your feeling?
Old Dec 23, 2006 | 02:08 PM
MasterKwan's Avatar
It's funny, when I had the mounts in my DC2, I had tons of vibration. Now in my EK/EJ, pretty much the same mounts, the vibration's barely noticable.
Old Dec 23, 2006 | 02:15 PM
dohcVTECeg2's Avatar
Default Re: Switch to Hasport, and still having kickbacks (MasterKwan)
this is common when you install hasport mounts. you get alot of vibration. it just takes time for them to seat properly. your motor should not rock at all once you put the mounts in. unless you didnt tighten them up right
dafreeeze
19
May 14, 2013 04:33 PM
imitati0n
Jan 3, 2011 05:44 PM
hondaapi
Oct 20, 2008 01:52 AM
Blazin Si
18
Oct 26, 2005 05:36 AM
zerogravitycrx
Aug 25, 2005 09:55 AM
