belt problems
For the pass few weeks my belts squeal whenever i turn up my stereo system loud. I checked the tension on all the belts and they are all good so my question is which belt do you think it is. A few people said that it is my alternator belt casue when my system is up loud it draws more power which makes it squeak. Oh yea its a 97 civic.
Thanks
Thanks
On the charging side you can check it by disconnecting the negative battery cable. If the car dies the alternator isnt charging. A faulty voltage regulator will cause a whining noise that will go away when you disconnect the big plug (while its running). And you can use a mechanics stethoscope, long screwdriver, or prybar to listen for a bad bearing.
Ritchie
17
Jun 17, 2007 10:02 PM
ATgrills.com
Aug 5, 2003 05:56 PM
