Is my TURBO def. BLOWNNNNNNNNNNNNNNNN????????????
Old Dec 22, 2006 | 06:28 PM
00BoostedGSR's Avatar
Default Is my TURBO def. BLOWNNNNNNNNNNNNNNNN????????????
Well today I was driving my car to work and it was running normal and then I got off the highway, and the next thing i know my blow off valve isnt working and my boost gauge is only reading vacuum and no boost.
So now when I drive I have no boost and my turbo is just a really expensive air intake.
Is there anything else except a blown turbo that could be causeing this??Or should I start looking for a new one!
Old Dec 22, 2006 | 06:33 PM
markaria's Avatar
Default Re: Is my TURBO def. BLOWNNNNNNNNNNNNNNNN???????????? (00BoostedGSR)
perhaps you have a large leak in your charge piping (such as a coupler coming loose etc)
Old Dec 22, 2006 | 06:36 PM
Synapse Motorsport's Avatar
Default Re: Is my TURBO def. BLOWNNNNNNNNNNNNNNNN???????????? (markaria)
Is your car smoking? You probably have a large boost leak if its not.
Old Dec 22, 2006 | 06:37 PM
shortdahri's Avatar
Check your intercooler pipes. You may have blown a silicone coupler loose causing no pressure. If thats the case, get yourself some T-Bolts Clamps.
Hope this helps.
Old Dec 22, 2006 | 06:49 PM
swappedcx's Avatar
Default Re: Is my TURBO def. BLOWNNNNNNNNNNNNNNNN???????????? (shortdahri)
what they said...I had my intercooler piping blow off 4 times. One time when J-K tuning was tuning my car, and once right after, the other times just on the road. They were on tight too with T bolt clamps. But damn it sounded like a tire blew off the first time when the pipe popped off.
Old Dec 22, 2006 | 07:45 PM
Mr HYDE's Avatar
Default Re: Is my TURBO def. BLOWNNNNNNNNNNNNNNNN???????????? (swappedcx)
check all piping and couplers. if your turbos blown and its making no boost IF THE CASE, you probably lost a wheel. my friends turbo completely blew off the exaust wheel and it shot out the back of the car in pieces
Old Dec 22, 2006 | 07:51 PM
b18sihatch's Avatar
sounds like a leak to me
Old Dec 23, 2006 | 06:43 AM
jameelrose's Avatar
can you hear the turbo spooling?
Old Dec 23, 2006 | 06:52 AM
PrecisionH23a's Avatar
Check your vacuum lines as well.
Old Dec 23, 2006 | 07:14 AM
coneheadsracing's Avatar
Default Re: Is my TURBO def. BLOWNNNNNNNNNNNNNNNN???????????? (PrecisionH23a)
If your turbo is still spooling, stop trying to boost You'll be spinning the **** out of it, and could trash it.
I've had both, pipes blow off, and i had a washer stop my exhuast wheel, amazingly didn't do damage. When the washer was in there, the car was really slow, due to it having a big restriction. When my pipes would blow off, it wasn't as slow, just no boost, and a really loud turbo spooling. I also have had my downpipe come loose, which then my wastegate wasn't functioning, i've had the wastegate arm come loose, thus no boost, and i lost a o2 bung plug, which also affected my car.
So, what is your car actually doing?
Old Dec 23, 2006 | 08:22 AM
93CX's Avatar
Default Re: Is my TURBO def. BLOWNNNNNNNNNNNNNNNN???????????? (coneheadsracing)
Sounds like a charge pipe.. happens all the time
Old Dec 23, 2006 | 09:50 AM
93supercoupe's Avatar
Default Re: Is my TURBO def. BLOWNNNNNNNNNNNNNNNN???????????? (93CX)
def a charge pipe or ripped couple
Maybe even a stuck open BOV
Old Dec 23, 2006 | 09:58 PM
Yep, thanks everybody it was my charge pipe hose.
Old Dec 24, 2006 | 06:42 AM
Topdawgg's Avatar
lol
come on now... thats the first thing you check...
invest in some good clamps and couplers... i beat the **** out of mine all summer at 12-13 psi and never popped one off..
Sticky2K
Aug 28, 2009 08:01 AM
00BoostedGSR
Dec 23, 2006 09:59 PM
1hotcivicSi
Mar 6, 2004 07:40 AM
It's*BOLO!!
Apr 22, 2003 07:27 PM
Nikos
Apr 14, 2002 08:00 PM
