How to do compression/leak down test with motor out of car?
Old Dec 23, 2006 | 10:11 AM
invisible's Avatar
wrong forum...delete.
Modified by Battle23 at 1:59 PM 12/23/2006
Old Dec 23, 2006 | 05:19 PM
DaveF's Avatar
Default Re: (Battle23)
id put a flywheel, at least a bellhousing on it, then jump the starter on a battery
Old Dec 23, 2006 | 05:52 PM
RC000E's Avatar
Default Re: (dturbocivic)
Yep....it works. As far as the leakdown goes, you can do it out of the car...only problem is the motor is cold so your numbers are going to be higher. If it's good cold though, it's certainly straight when the rings are expanded and everything is heated up.
Old Dec 24, 2006 | 03:46 AM
blackeg's Avatar
Default Re: (RC000E)
#s will be lower when cold, the pistons and rings are not warm and have not expanded
Old Dec 24, 2006 | 04:53 AM
DaveF's Avatar
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">#s will be lower when cold, the pistons and rings are not warm and have not expanded</TD></TR></TABLE>
i think he knew that, just a slight mistype...
Old Dec 24, 2006 | 09:27 AM
RC000E's Avatar
Well, I meant that your leakdown numbers (versus compression) will be higher, so it's safe to assume if they are acceptable with the motor cold, then your certainly in good shape with the motor warm.
I admit I did type that a little hard to understand. So to be very clear to the O.P.
Compression psi will be lower with motor cold
Leak down numbers will be higher (i.e. larger percentage leakdown) with cold motor
vtibrazil
10
May 30, 2008 12:39 PM
GdmLaz
Jan 28, 2008 04:54 PM
RAS Motorsports
Dec 10, 2003 05:16 AM
shamoo
Sep 25, 2002 02:53 PM
