b18b question(a bit noobish if i do say so myself)
ok, people say well the b18b is so much less than the b16. but i have recently began to look into the 2 and i have found the prices nearly the exact same. am i looking in the wrong places or something? hmotorsonline.com, ebaymotors. for complete swaps either or is about 2g's give or take a little. unless some one can find that they are not the same price.
basically the question is where can i find b18b's for cheap and a complete swap(that is cheaper than a b16), thanks.
no it was obd1 b16a xsi version(think like 93 japan version, it says it obd1) 170hp and 113ft lbs of tq if i am not mistaken. its weird. do you think that my local junk yard might have one for cheaper(b18b that is)?? everywhere else they are practically the same. i am thinkin b18b with a b16 tranny possibly.
get the b18b complete change over from hmotorsonline they will give you everything you need to completely swap it over to your ek including all the right mounts swap a vtec head on later i believe the b16 tranny has a little bit shorter gears and get hondata
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unit44justin »</TD></TR><TR><TD CLASS="quote">get the b18b complete change over from hmotorsonline they will give you everything you need to completely swap it over to your ek including all the right mounts swap a vtec head on later i believe the b16 tranny has a little bit shorter gears and get hondata</TD></TR></TABLE>
hmotorsonline does not have b18b's complete change overs for less than a b16(its actually more expensive)please look what i posted and for the record the b16 tranny has alot shorter gears.
i think cause now everybody know b16's are garbage at least the bottom end is. how much are those places trying to get for a b18b? i got a full ls swap for 600 just mising a few little things that i got for free at picknpull.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">i think cause now everybody know b16's are garbage at least the bottom end is. how much are those places trying to get for a b18b? i got a full ls swap for 600 just mising a few little things that i got for free at picknpull.</TD></TR></TABLE>
wow that would be incredible if i could get a full b18b swap for around less than a G. i would prob be the happiest person alive.
fastrxu
25
Jan 17, 2010 12:38 PM
TurboEM1
Nov 9, 2005 08:57 AM
