O2 sensors and cap and rotor for OBD0 B16A from WHAT CAR?
OK I need the 2 single wire O2 sensors and a cap and rotor for my OBDO B16A. I have asked my local shop but they dont have any idea which car they would be off. What car and year and engine should I tell them to get the correct parts? Any help appreciated.
If I remember correctly, the 90-91 Si had the same o2 sensors as the JDM B16.
As far as the cap and rotor, I went with 90-93 Integra LS cap and rotor.
Thanks EL Vap. Can anyone back him up? I want to be sure before I buy the stuff. I will do the 90-93 LS cap and rotor though. Does it bolt right on like stock? No fitment issues?
Yup the 90-91 Integra cap and rotor are perfect for a 1st gen b16a in case anyone wondered. ANd you can use 2 universal 1 wire o2 sensors and they work perfect too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">If I remember correctly, the 90-91 Si had the same o2 sensors as the JDM B16.
i always used the same thing. BTW the 90-93 LS cap and rotor are also the same as the 90-91 Si.
same part number.
</TD></TR></TABLE>i always used the same thing. BTW the 90-93 LS cap and rotor are also the same as the 90-91 Si.
same part number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">
same part number. </TD></TR></TABLE>
no its only the 90-91 ls cap and rotor, the 92-93 ls was obd1 and had the different cap and rotor, I had both a 91 and 92 integra I know 4 sure
You can go either way..I went with the crx/civic si 90-91 cap & rotor and put it on my b16a just yesterday cuz the one on my engine was cracked and old from japan..I robbed it off my crx si cuz it was right here lol...Good luck...Also, run NGK irridium's!..The NGK R's run shitty and foul quick..
Go n 4 10s
Mar 17, 2006 01:44 PM
.ShawnD.
Aug 16, 2002 03:58 PM
