HELP...rear GSR disc brake conversion with Ls master cly?
hey guys i need help here....i did a rear gsr disc conversion.
so if i use my 94 Integra Ls brake booster and use my 93 civic cx MC?
would that work?
Modified by JDM RHD eg6 at 4:26 PM 12/22/2006
would that work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Sure, why not? Are you using the LS brake booster too? </TD></TR></TABLE>
coo yes sir
coo yes sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM RHD eg6 »</TD></TR><TR><TD CLASS="quote">
coo yes sir</TD></TR></TABLE>
Now is your vehicle ABS equipped? Because if it isn't, I am almost positive you will have to bend the lines.
i did the conversion on my 93 civic cx...i dont have ABS...can i just replace my master cly? hahahha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You don't need a MC for a rear disc conversion BTW.</TD></TR></TABLE>
what would i need then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM RHD eg6 »</TD></TR><TR><TD CLASS="quote">so if i use my 94 Integra Ls brake booster and use my 93 civic cx MC?
would that work?</TD></TR></TABLE>
NO, it will not work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Now, for the optional **** that WILL make a difference in braking and mostly pedal feel:
1994-2001 GS-R, LS, RS, any Integra brake booster. This bolts into any 1992-1995 with ease. BOLTS right in.
***IMPORTANT***
You MUST have an Integra booster in order to run an Integra master cylinder! Although the lines fit perfectly on the Intgegra RS mastercylinder, no Integra master cylinder will bolt up to the CIVIC brake booster. Get the Integra booster and you will have to run an Integra master cylinder too.
Integra RS master cylinder. The base model RS Integra had NO ABS so the lines match up PERFECT with any non-abs Civic - which most of you have. I have done this in my own car and it truly bolts in.
The Integra master cylinder is a 15/16th whgile the Civic non-abs uses a smaller 13/16th master cylinder.
[Modified by B18C5-EH2, 2:53 PM 4/14/2002]</TD></TR></TABLE>
Modified by shyboi4u at 6:41 PM 12/22/2006
***IMPORTANT***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM RHD eg6 »</TD></TR><TR><TD CLASS="quote">Thanks mang
btw search and you can also use the stock BB and a 91 civci ex Mc....
yeah i already know that too. i forgot to mention that.
</TD></TR></TABLE>yeah i already know that too. i forgot to mention that.
what would i need then?</TD></TR></TABLE>
You won't need it because you won't be pushing more fluid than you do now.
EusebioSam19
Jan 28, 2011 05:06 AM
Parn_36
Mar 29, 2005 12:42 PM
