Exhaust fumes creeping into cabin! Is it my WG dump?
Old Dec 22, 2006 | 10:39 AM
tweekerz's Avatar
Default Exhaust fumes creeping into cabin! Is it my WG dump?
My setup is 3" dp + 3" piping + Vibrant flat black muffler. I'm still running open wastegate dump.
When I'm in idle or driving slow in first gear with the heater on I can smell lots of fumes. No problem while driving. My heater is on fresh air and not recirulation. Now I'm guessing it has to be my WG dump but I thought they only open up when I'm under full boost.
Any ideas?
Old Dec 22, 2006 | 10:46 AM
EJ1 wilcox's Avatar
Default Re: Exhaust fumes creeping into cabin! Is it my WG dump? (tweekerz)
What's your catchcan setup like? Are you running a cat?
I used to have an open PCV system, with tubing open to the ground, and in traffic I would get sick from the fumes. I did a proper catchcan setup and the fumes were less.
Nothing should be coming out of your wastegate dump unless you are at full boost, so I wouldn't worry about that.
Old Dec 22, 2006 | 11:26 AM
tweekerz's Avatar
Default Re: Exhaust fumes creeping into cabin! Is it my WG dump? (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">What's your catchcan setup like? Are you running a cat?
Nothing should be coming out of your wastegate dump unless you are at full boost, so I wouldn't worry about that. </TD></TR></TABLE>
No catch can yet, and I'm running no cat.
Old Dec 22, 2006 | 11:32 AM
EJ1 wilcox's Avatar
I would definately figure out a catchcan solution first off. Even if it's a vented can with internal baffling, at least it would be separating some of those vapors out before you breathed them in.
I used to get headaches every day after driving home through traffic, and I couldn't figure out why. lol. Then I installed a catchcan and the headaches went away.
Breathing those fumes is not good for you.
Old Dec 22, 2006 | 11:37 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">I would definately figure out a catchcan solution first off. Even if it's a vented can with internal baffling, at least it would be separating some of those vapors out before you breathed them in.
Breathing those fumes is not good for you. </TD></TR></TABLE>
Yeah its been on my to do list since I've been boosted. Where are those fumes coming from?
Old Dec 22, 2006 | 11:39 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah its been on my to do list since I've been boosted. Where are those fumes coming from?</TD></TR></TABLE>
You know what... the hose that connected my valve cover to my old intake is not connected to anything...
namewasdallas
Apr 7, 2010 08:27 AM
a1320honda
Jan 7, 2008 02:43 PM
crucian
Dec 3, 2006 11:05 AM
Quickgti1.8t
Jul 29, 2006 09:35 PM
Built B16A
Feb 18, 2004 12:02 PM
